Yes, I have it working - at least on a 72-7730A.
Did you enable the SEND mode by holding down MAX/MIN button for 2 seconds? Pressing EXIT will turn it off again.
The one bug I see is if data reception times out, then you may have to click "USB Disconnect" to reconnect again.
