I'm starting restoration of an old Tektronix R5030 scope, from around 1969. Nothing special about the scope itself except that it's very pretty, and since I haven't yet found a service manual the project so far involves just cleaning, fitting a mains IEC socket, and other mechanical fixups.
But the scope contains an unusual device Tek came up with for readout of the attenuator and timebase settings.
The front panel knobs don't have any numbers printed around them. Which is the first time I've ever seen that in an old scope. Nor is there any on-screen readout, unlike the later 7000 series Tek scopes.
Instead they have a cute assembly using light bulbs and light fibers, in which the fiber ends are arranged at a front face to form the various numbers and letters they needed.
At the moment the scope has a fuse-blowing problem that means this device is not lighting up. Pity. For a little while some of the legends did light up, but by Murphy's law that failed just as I was about to take photos of it. So did the sweep at the same time, and a power supply LV 3A fuse blew. So something died just then, somewhere in the scope. Fixing that will have to wait till I find a schematic.
I've found a source for an original manual, but can't afford it (and the postage) atm. If anyone knows of an online pdf, please let me know. Or a cheap paper original, of course!
Normally I'd try to restore stuff to original condition, but with this one, since I already had to hack it to add the IEC socket, I'd really like to replace all the incandescent bulbs with LEDs. If at all possible, given that they may be AC driven, and of course from a voltage source, as opposed to via current limiting resistors. Orange or yellow LEDs shouldn't make it look _too_ anachronistic. Ha. Or maybe I'll just go with blue, for a laugh.
The scope is complete, I just had the covers and CRT fascia removed when I took the photos.
Very interesting to see that Tektronix had this nice printed-anodized aluminum front panel technique perfected so early. I'd thought it was something they developed first with the 7000 series scopes. But apparently not - all the 5000 series scopes had it too. As well as an early form of the plugin module system that worked so well in the 7000 scopes.
Incidentally I'm also looking for Tek 5103N-D12 and D13 mainframe scope manuals. Complete, unlike the partial copies at
http://bama.edebris.com/manuals/tek/5103n/ Tek 5103N_v6.pdf 8MB
http://elektrotanya.com/tektronix_type-5103n_oscilloscope_instruction_sch.pdf/download.html 38MB
Both of which are from the same original scan (eletrotanya copied the BAMA one, but somehow made the filesize 5 times larger while editing out the handwritten note on the title page that mentions it's incomplete.) Both contain only the lower module of the scope, not the upper CRT and deflection amps module.
