Hi guys. I read a couple of topics here and over the net about how to make a DIY injection transformer that covers a lot of frequencies - usually, it is used to test power supplies for stability. As far as I know, the best is the B-WIT 100 from Omicron Lab. So I found a photo of the internals - Dave did a teardown too, and I started to search for a suitable core. The core is "special" - not a ferrite core like most inductors. As I think the best solution is a core from Nanocrystalline. It is similar to the traditional toroidal transformer winded with sheet of metal, but the material is very thin and fragile. I measured it and it is 0.001mm. A piece of it just fell out.
So, I did some research and found this inductor from Wurth: 744839208072. Since I've been ordering a lot of Wurth, I asked for a free sample. I needed to remove the original wire, then to dremel some of the existing plastic material until I got a nice round ring core. I measured the inductance and with 41 turns (filling the entire core) I got about 250mH. The B-WIT 100 contains 40 turns. I used a twisted wire from an old lan cable.
There is a screenshot of the bode plot I did with my scope and I believe the final result is pretty good for a transformer for free
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Just wondering why there is a peak at the high frequencies? The output of the transformer is not loaded. Can someone measure the inductance of the B-WIT 100 transformer?
What do you think guys about the graphs?
PS: I will do another capture but I will zoom the frequency response. Now it looks very flat and probably it isn't.
