Author Topic: UNI-T MSO3054HD Oscilloscope  (Read 521 times)
Offline egonottoTopic starter
« on: July 01, 2024, 09:43:12 pm »
Hello,
in the new video from Shahriar about the Microwave Symposium, Washington 2024, a new 12-bit oscilloscope MSO3054HD from UNI-T can also be seen briefly. I can't find anything at UNI-T yet. The link in the image does not provide any information, but you can already see some data in the image.
Best regards
egonotto
The following users thanked this post: shabaz, TurboTom
Offline shabaz
Re: UNI-T MSO3054HD Oscilloscope
« Reply #1 on: July 01, 2024, 10:57:27 pm »
Managed to screenshot a little bit, and this was the info on their webpage (had to disable JavaScript to see it).
Bandwidth: 500MHz Also available MSO3034HD 350MHz
▪ Vertical Resolution: 12-bit HD, 16-bit ERES
▪ 4 Analog Ch/16 Digital Ch, Logic Analyzer SW included (probes optional)
▪ Max Sample Rate: 5GSa/s [EDIT: as mentioned by @thm_w below, this looks definitely like a typo, should be 2.5GSa/s] 2.5GSa/s per channel
▪ Memory Depth: 500Mpts per channel
▪ Max Capture Rate: 1,500,000 wfms/s per channel
▪ Arb Waveform Generator: Dual Channel 50MHz option
▪ 10.1-Inch UltraPhosphor3 Touchscreen Display
▪ 5-Year Warranty
Power Analyzer: (option) power quality, harmonics, switching loss, ripple wave, loop analysis, safety operation area
Spectrum Analyzer: up to 1GHz. Up to 4Mpts enhanced FFT, functions such as frequency setting, waterfall plot, detection setting, and marker are included
Bode Plot Analyzer: Option (also requires AWG option)
Bus Decode: Included: RS232/422/485/UART, I2C, SPI
Option: CAN, CAN-FD, FlexRay, LIN, SENT, MIL-STD-1553, ARINC429, Manchester, I2S/LJ/RJ/TDM (audio)
DVM/Frequency Counter: 7-bit
Measures up 54 measurement parameters
Mask limit testing
Web server (SCPI control, remote access wired and Wi-Fi)
« Last Edit: July 02, 2024, 10:47:23 pm by shabaz »
The following users thanked this post: egonotto, thm_w, TurboTom, coromonadalix, Anthocyanina
Online Anthocyanina
  • The Sara
« Reply #2 on: July 02, 2024, 07:22:45 pm »
it seems to be available for purchase on their chinese website:
https://instruments.uni-trend.com.cn/list_221/2862.html
The following users thanked this post: shabaz, egonotto
Offline thm_w
  • Non-expert
« Reply #3 on: July 02, 2024, 09:19:14 pm »
So 12-bit 2.5Gs/s for $2,200 USD.
I'm not sure who would buy it over the Siglent SDS2204X HD at $2,400. Or a DHO1074 for $900.
BUT, they are definitely driving down the price of scopes with probe sensing on them, it seems (siglent doesn't have it). And 5 year warranty is always great.
▪ Max Sample Rate: 5GSa/s per channel
I think this has to be a typo, everywhere else says 2.5Gs/s max. Not even per channel.
The following users thanked this post: egonotto, Anthocyanina
« Reply #4 on: July 02, 2024, 09:26:42 pm »
You confuse active probe support with probe sense, they are 2 different things.
SDS5000X and SDS3000X HD are where Siglent models start providing active probe support.
Probe sense OTOH is provided with SDS1000X HD, SDS2000X Plus and all higher models, 8 or 12bit.
« Reply #5 on: July 02, 2024, 09:49:29 pm »
Hello,
If the MSO3000HD really had 2 x 5 GSa/s and at least 2 x 500 MSa, I would find it interesting.
However, if it had 2 times 2.5 GSa/s and only 1 time 500 MSa, I would no longer find it interesting.
Best regards
egonotto
Online Martin72
  • Testfield Technician
« Reply #6 on: July 02, 2024, 09:56:54 pm »
Active probe interface only makes sense if you have corresponding probes on offer - is that the case?
Otherwise, there are strong visual references to Rigol, and the advertised maximum 1,500,000 Wfms/s is also "suspicious".
(Kierkegaard)
Online Anthocyanina
  • The Sara
« Reply #7 on: July 02, 2024, 10:49:41 pm »
it seems this scope also has 50 ohm termination, i missed the label stating that in the pictures! i'm liking the design of this scope too, it looks like the front panel has a bunch of light pipes behind the encoders, and from the few images that appear to be real pictures, it doesn't look bad. Not sure about the cyan strip at the top, but i don't mind it either. This design looks much nicer than rigol's latest offerings. They've put this one in their 3000 class, so maybe 2k and 1k class 12 bit scopes coming from them too?
Offline shabaz
« Reply #8 on: July 02, 2024, 10:50:43 pm »
Thanks; you're right. I've updated the comment to stop getting people's hopes up!
Offline shabaz
« Reply #9 on: July 02, 2024, 11:01:28 pm »
The large memory depth is nice to see. In terms of usability, perhaps not to everyone's taste, but I really like the dual multipurpose controls that are on Tek instruments, and this Uni-T 'scope has them too.
Offline Antonio90
« Reply #10 on: July 03, 2024, 09:31:27 am »
Looks interesting on paper. The style is a bit in line with Rigol's gaudy "gaming" visuals. I don't like it, but I don't care too much. It's a pity the dark coloured scheme has won, no biggie though.
In any case, I don't know what's there to entice customers to buy. Everything is a paid option (including FRA, which actually needs two options), and the price advantage doesn't seem enough to chose it over already proven brands like Siglent and Rigol.
At €1500 it would be an enticing option, at €2200, not so much.
EDIT: 135Vrms max. rating. A bit lower than usual bench scopes. No limit on Vpeak though  ;D
« Last Edit: July 03, 2024, 09:38:06 am by Antonio90 »
