I have the same errors. Did you manage to fix this issue?
Fixed. The scope was originally with ver 2.10 and I tried to resurrect it with ver 2.35 which in this case was incompatible.
Then I prepared a flash drive with the 2.20 version and it worked immediately. One more DSOX3034A saved
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
