While aneng's scope probably has a different issue, I thought I'd share my similar tale of getting a lovely analog scope with a deflection problem.
A while back, I bought an AN/USM-488 scope on eBay. This is a militarized version of the Tektronix 2235. In this case, I think the militarization just consisted of changing a label or two to show the US military nomenclature. Just like aneng, I bought it as much for its looks as its features. My specific application for it was to use it as a modulation monitor for my great, big
T-368C/URT radio transmitter. An analog scope is the right thing to use for that application, the 2235 is a good size to sit on top of the transmitter next to the outboard MD-239A/GR FSK modulator box, and the military markings are icing on the cake.
When it arrived, I was disappointed to discover that one side of the horizontal drive was not working. I could have returned the scope, but I really wanted one with the military markings on it. So, I decided to take it apart before contacting the seller, and I'm glad that I did. In this scope, the deflection plate connections are made to individual pins sticking out of the sides of the glass envelope, rather than through the multi-pin connector on the back of the electron gun. The connections are made with individual wires that have female contacts installed on the ends. Once I dug far enough into the scope to see the bottom of the CRT, I discovered that one of the two horizontal deflection wires had simply fallen off the pin during shipping. I plugged it back in, and the scope began working perfectly!
Most repairs aren't that easy, but sometimes you get lucky. Good luck to you, aneng!
