Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
I need to know the History of FLUKE 87 ( 1988 - 2010 )
« previous
next »
Print
Search
Pages:
Prev
1
2
3
4
All
Go Down
Author
Topic: I need to know the History of FLUKE 87 ( 1988 - 2010 ) (Read 98621 times)
bluey
Regular Contributor
Country:
Re: I need to know the History of FLUKE 87 ( 1988 - 2010 )
Reply #75 on:
June 06, 2020, 10:48:19 am »
Reading the theory of operation more carefully, the resistance function is a comparison function and doesn’t use a “constant current circuit” per se. Therefore the “sanity check” internal resistor test doesn’t achieve that much apart from being a fuse test. The voltmeter could be completely wrong and resistance of the internal resistor would still measure perfectly correct.
Fortunately, the band gap voltage reference in the 87-I to 87-III is quite stable. The LM285BXZ-1.2 Micropower Voltage Reference Diode is described on page 7-58 of the National Semiconductor Linear Databook Vol 2 1988. Long term stability is 20ppm per 1000 hours. Temperature stability is 30ppm/degC.
LMx85-1.2-1988NationalLinearDatabookVolume2.731107566.pdf
(269.77 kB - downloaded 216 times.)
https://usermanual.wiki/Document/1988NationalLinearDatabookVolume2.731107566.pdf
My 1991 87-I never adjusted reads the same as my new Hioki DT4222 - at least for volts.
https://www.eevblog.com/forum/testgear/hioki-dt4222-compact-trms-multimeter-teardown/msg3089246/#msg3089246
86-V and presumably 87–IV (cant find a document listing the parts) use a higher spec 2.5V voltage reference.
https://www.eevblog.com/forum/beginners/what-is-the-voltage-reference-part-in-the-fluke-87-v/msg3089331/#msg3089331
LT1790ACS6-2.5 Micropower SOT-23 Low Dropout Reference Family has tolerance of 0.05% and thermal stability of 10ppm/degC. The voltage reference in 87-I to 87-III has tolerance of 1% and needs trimming to be accurate.
Last Edit: June 07, 2020, 04:49:01 am by bluey
Logged
Neomys Sapiens
Marco1971
Print
Search
Pages:
Prev
1
2
3
4
All
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
