Author Topic: Rigol DG1022 how to update the firmware?  (Read 27184 times)
Offline usagi
Re: Rigol DG1022 how to update the firmware?
« Reply #25 on: March 27, 2017, 01:08:12 am »
In the end I tried just putting the bootloader AND FW files on the same USB stick then ran the startup procedure again.. This time It worked! And the updated FW had gone in too :)
i can't see how this is possible? Both the bootloader and the FW file are named DG10x2Update.GEL
Can you exactly and precisely explain what you did? I have a bricked 1022a and need to recover it.
Offline orbiter
  • -0 Resistance is Futile
« Reply #26 on: March 27, 2017, 02:12:32 am »
TBH I can't remember now exactly how I did it... Perhaps I removed a letter from one of the file names. Leave the .GEL in place though.
Offline RichardFr
« Reply #27 on: October 03, 2020, 05:44:48 pm »
Hello,
I have a problem after to have updated my old DG1022 :
Before I had : 00.03.00.08.00.02.08
I updated it using https://beyondmeasure.rigoltech.com/acton/ct/1579/p-00ac/Bct/-/-/ct36_0/1?sid=TV2%3AQ2jKaGpUj (03.00.00.01).
Firstly I upgraded to bootloader 03 (from folder DG1022X(DSP)Update(Bootloader)_03 )
Then I updated firmware (from folder DG1022X(DSP)Update(Normal)_00.03.00.00.01)
At startup, I see the following version number : 03.03.00.08.00.03.00
So the upgraded seems to have succeed.
The instrument starts well and displays the user interface, but some of the buttons (numeric keypad, last button on top of CH1/CH2...) are not usable anymore.
When I press any, the device shows the following message : "the key has been locked. Use please unlock".
Any suggestion to fix this ? Thanks a lot.
Offline RichardFr
« Reply #28 on: October 03, 2020, 06:00:21 pm »
You can ignore my message, I fixed it using SCPI commands :
https://www.batronix.com/files/Rigol/Funktionsgeneratoren/_DG1000/DG1000_UserGuide_EN.pdf (page 97)
I just put on a usb stick a file "unlock.scpi" with following content :
SYSTem:KLOCk ALL,0
And all keys seem to work again. Even if the instrument is old, I left the comment in case it could be useful to anybody !
« Last Edit: October 03, 2020, 06:03:00 pm by RichardFr »
The following users thanked this post: egonotto, Warhawk
Offline Warhawk
    • Personal resume
« Reply #29 on: October 04, 2020, 08:14:08 pm »
SYSTem:KLOCk ALL,0
Thanks for the effort sharing this with us. It is useful.
Offline RichardFr
« Reply #30 on: October 06, 2020, 02:59:38 pm »
You're welcome. I'm surprised to have not seen this weird issue after a firmware upgrade reported yet :).
