does the print button not create a screenshot?
I wonder if the 167xG disks are around :/
I went into ftp, logged in as control
cd /system/disk/hard/system
200 Remote Directory changed to "/system/disk/hard/system".
ftp> dir
200 PORT command ok.
150 Opening data connection for (192.168.0.100,60327).
-rw-rw-rw- 1 1 1 20494 lg165.bdf
-rw-rw-rw- 1 1 1 1116 readme
-rw-rw-rw- 1 1 1 131328 rom
-rw-rw-rw- 1 1 1 19595 sm165.bdf
-rw-rw-rw- 1 1 1 654848 system.lan
-rw-rw-rw- 1 1 1 245248 sys_014
-rw-rw-rw- 1 1 1 193792 sys_025
-rw-rw-rw- 1 1 1 706560 sys_034
-rw-rw-rw- 1 1 1 300288 pvtest_
-rw-rw-rw- 1 1 1 118272 pv_014
-rw-rw-rw- 1 1 1 27136 pv_025
-rw-rw-rw- 1 1 1 359424 pv_034
-rw-rw-rw- 1 1 1 212736 optc_032
drwxrwxrwx 1 1 1 1024 messages
drwxrwxrwx 1 1 1 1024 objects
drwxrwxrwx 1 1 1 1024 tmp_025
-rw-rw-rw- 1 1 1 548 system.map
226 Transfer complete.
ftp>
and there are the files, now I dont know when it runs the symbol util if it fires it from disk here or flash or what, but you could probably drop the new symbol on it and see if it runs and change it back. rename the current one, drop in the new, rename it back if it does not work.
I believe, 014 - oscilloscope, 025 - pattern gen, 034 - deep la, the PV_ files are the test files
rom contains
"V4.1 COPYRIGHT 1983, 1984, 1985, 1986 SOF
TWARE COMPONENTS GROUP, INC. A"
and a Motorola 1981 copyright for some floating point stuff..
