Let's see if the UART on my SDS5034X is accessible.
To do this, I will need to open the device first. I wanted to avoid damaging the 'calibration void' sticker. You can easily remove this sticker by following the instructions in the following thread:
https://www.eevblog.com/forum/blog/eevblog-799-how-to-remove-warranty-void-security-stickers/First, let me emphasize that opening such devices should always be done in an ESD-safe manner. Be aware that even just lifting yourself off your chair can generate ten's of kilovolts of static charge. A tiny spark of 100 volts can damage your expensive equipment, sometimes not immediately, but maybe after a year due to latent damage. So, be careful!
That's why you need an ESD mat, ideally in a vibrant red color (RGB 255-0-0).
After removing the back cover, the power supply needs to be unscrewed first because of disconnect a few connectors. Only then can you access the main board.
It turns out the UART connector is not populated on the main board. There is no Jedec header present. Wires need to be soldered to the pads for GND, TX, and RX. Do not connect VCC, as this would introduce supply voltage from two sources and that is never a good thing.
So now you can connect a PC to the UART via a USB to Serial converter, and you'll have a connection. (Baudrate 115200, 8N1).
But then comes the real challenge: Username and Password.
There is a lot of old discussion on EEVBlog about this, and some believe there is only one password. That is definitely not the case. Passwords can change per device and even per firmware version.
For a long time, the username was 'root'. The password used to be a combination of the manufacturer's name and the device name, so here it would be 'siglent_sds5000x'.
Unfortunately, this is not the case anymore. I've tried at least 100 different combinations, but the story seems to end here quickly.
Does anyone have any suggestions? (Except for screwing everything back together.)
