Hello,I am a beginner and breadboarding an 'electronic dice' circuit that uses a CD4017 decade counter.I would like to explore how this device works and wondered if a cheapish USB logic analyser like this one ...http://www.ebay.ca/itm/PC-USB-Logic-Analyzer-34CH-100MHz-125MHz-With-Support-I2C-SPI-UART-PWM-/321589919850?pt=LH_DefaultDomain_0&hash=item4ae040c06a... might be used.I have a signal generator that can supply the clock cycles and wondered if this LA will show me how the output pins change.I don't want to spend more than $80-100.Thanks.
