I put the Li-ion battery purchased on Aliexpress. Measured capacity 650 mah.
Built-in PCB protects against overcharging at 8.44 volts, and against overdischarge.
It is perfectly charged by the built-in charging of the meter U1252A and there is no danger of overcharging.
In the photo the charge limit and the type of viscera.
