A DLP example. I did this to quickly check how harmonics are affecting the wideband power measurement.
The analyser should be set up so the signal and it's harmonics are visible in a single sweep. The DLP takes power of the highest peak (HIPK), then it adds power of all harmonics above 26 dBc. Then it reports the difference between HIPK and the summed power.
FUNCDEF THD_DB,@
LCLVAR NP,0 ;; number of peaks
LCLVAR HIPK,0 ;; highest peak amplitude
LCLVAR I,0 ;; peak number
LCLVAR P,0
LCLVAR P1,0
LCLVAR YPOS,700 ;; current vertical display position
LCLVAR PWR,0 ;; total power
LCLVAR FFR,0 ;; fundamental frequency in display units
SNGLS
EM
TS
MKPK
MOV HIPK,MKA
SUB MKPT,HIPK,26 ;; harmonic level > 26dBc increases total power by more than 0.01dB
MOV MKPX,3
HD
MOV NP,PEAKS TRB,TRA,AMP
PA 100,YPOS
IF NP,GE,25;THEN
TEXT %TOO MANY PEAKS: %
DSPLY NP,3,0
ABORT
ENDIF
IF NP,EQ,0;THEN
TEXT %NO PEAKS FOUND%
ABORT
ENDIF
SUB FFR,TRB[1],1
TEXT %NPEAKS = %
DSPLY NP,2,0
SUB YPOS,YPOS,40
REPEAT
ADD I,I,1
MOV P,TRB[I]
SUB P1,P,2
IF TRA[P],GE,TRA[P1];THEN
ADD P1,P,2
IF TRA[P],GT,TRA[P1];THEN
IF P,LT,FFR;THEN
TEXT %NON HARMONIC PEAK: %
DSPLY P,3,0
ABORT
ENDIF
SUB P,TRA[P],600
MPY P,P,LG
DIV P,P,60.0
ADD P,RL,P
IF I,LE,12;THEN
PA 150,YPOS
SUB P1,P1,3
DIV P1,P1,600.0
MPY P1,P1,SP
ADD P1,FA,P1
DIV P1,P1,1E6
DSPLY P1,4,0
TEXT %MHz = %
DSPLY P,5,2
SUB YPOS,YPOS,40
ENDIF
EXP P,P,10
ADD PWR,PWR,P
ENDIF
ENDIF
UNTIL I,GE,NP
LOG PWR,PWR,10
PA 100,YPOS
TEXT %SUM POWER = %
DSPLY PWR,5,2
SUB YPOS,YPOS,40
SUB PWR,PWR,HIPK
PA 100,YPOS
TEXT %DISTORTION = %
DSPLY PWR,5,2
TEXT %dB%
DLPs do not allow comments. ";;" comments are removed by the script I use for uploading.
