I really like where this discussion has gone and keep it up!
I'm trying to avoid having racks of equipment. I've been there and done that stuff with gear before and I don't have an abundant desire to just collect stuff to build up a big wall of dials, buttons and flashing lights.
I'm warming to the idea of fibre connected siggen (for EMI control) with a DSP or similar to drive a DAC and ADC with high quality output stage.
I do need something at the circuit end where I can put probes against pins and read the signal as it moves through a circuit board or set of components. This WILL include a signal that's post amplification stage so greater than line level. All conversation to date in other threads says this isn't a soundcard.
I'm trying to avoid building my own equipment but I can really see the advantage of what blueskull has done and am quite interested in that as an option!
I still can't seem to get past the need for a scope to see the signal at pins through a circuit board.
There must be something that I'm missing in this part of the process. What's the obvious thing that am I missing here, or is a DSO the right tool in that part of the process?
