My HP6612C, when disconnected from anything shows a current level of about -0.7mA, is this because it needs to be calibrated? The volts hover around 9.5mV (with the output switched off).
I bought it from someone in Korea on eBay and although it does have a relatively recent calibration sticker on it, perhaps the environmental difference between the UK and Korea is causing this? Or is it within spec? I can't find the bit in the manual which tells me...
AmpsVolts
