Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Maynuo M9712 zero current measured value (output off)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Maynuo M9712 zero current measured value (output off) (Read 852 times)
manupthehills
Contributor
Country:
on:
October 15, 2020, 11:57:22 pm »
I own an M9712 electronic load that I'm about to calibrate (adjust).
The main board doesn't look too clean and I measure 32uA when 12V are applied to the input. This current is measured when the output is off.
Not sure if this is a normal value for this instrument or if this is the result of the dirty PCB...
Anyone owning this model can please run the same measure and reply with the value?
Thanks
Logged
Tjuurko
Regular Contributor
Re: Maynuo M9712 zero current measured value (output off)
Reply #1 on:
October 16, 2020, 09:01:54 am »
And if you turn off the voltage measurement circuit?
MENU -> SYSTEM SET -> TERMINAL SET -> BACK
Logged
Pinkus
Frequent Contributor
Reply #2 on:
October 16, 2020, 02:13:37 pm »
Same with my M9712: I measured 33µA. Even if the unit is fully switched off (main power) it takes 27 µA.
... and mine is definitely clean inside!
Logged
Tjuurko
Regular Contributor
Reply #3 on:
October 16, 2020, 03:36:51 pm »
In my case (M9812), all parasitic consumption goes to the voltage measurement circuit (R=365k).
60V - 164 µA
50V - 137 µA
40V - 110 µA
10V - 27.2 µA
When switching to the rear panel (no wires connected to the rear panel), the consumption is 0.
Last Edit: October 16, 2020, 03:41:11 pm by Tjuurko
Logged
manupthehills
Contributor
Country:
Reply #4 on:
October 16, 2020, 05:10:14 pm »
Thank you guys! That saved me a lot of work.
I also measured the input current at the front terminals in the other two configurations:
- 12V front terminals: 32.6uA
- 12V rear terminals: 120nA
- 12V mains disconnected: 27.7uA
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
