Author Topic: HP3548 / HP3457 OLED display  (Read 22991 times)
Offline sagias
  • Country: gr
Re: HP3548 / HP3457 OLED display
« Reply #75 on: March 11, 2024, 11:52:56 am »
fw compiled and works flawessly
i provide the filee
Offline cncjerry
« Reply #76 on: March 12, 2024, 04:15:39 am »
What oleds did you use?
Offline Kean
    • Kean Electronics
« Reply #77 on: March 12, 2024, 05:30:05 am »
The ones linked earlier in the thread are no longer available, but at least the listing with specs and dimension drawing are still there.
I found another listing with similar specs, pin out, and dimensions - but I have not ordered any yet.
https://www.aliexpress.com/item/1005005770683719.html
The price of these is better that the previous listing, but I also saw some even cheaper but from "less reputable" sellers (not necessarily untrustworthy, but just lower reputation).
I will probably order 50 of them in the next couple of days as I want to convert a few meters, and can use these on other projects as well.  I guess I need to order the PCBs and other parts too...
Offline sagias
  • Country: gr
« Reply #78 on: March 12, 2024, 05:36:08 am »
As described on xyphros github
Offline sagias
  • Country: gr
« Reply #79 on: March 16, 2024, 11:03:28 am »
Prove
Offline Miti
« Reply #80 on: April 02, 2024, 02:51:24 pm »
What about this OLED? Reputable and the visual area seems to be a little wider, it fills the space between digits better.
https://www.buydisplay.com/white-0-87-inch-oled-display-panel-128x32-iic-i2c-ssd1316
Edit: Ignore, the visual area is the same, just different source.
« Last Edit: April 02, 2024, 03:02:22 pm by Miti »
Fear does not stop death, it stops life.
Offline Kean
    • Kean Electronics
« Reply #81 on: April 07, 2024, 06:25:59 am »
I've just received 20 PCBs and 60 of the previously linked OLEDs [1].  Hopefully in the next week or two I will find time to assemble a sample and check operation.
If any of the Aussie followers of this topic are interested, then feel free to DM me your interest in either bare or partially assembled PCBs.
I may have some OLEDs left over from my builds, but otherwise it is not hard to source them yourselves.
[1] https://www.aliexpress.com/item/1005005770683719.html
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #82 on: May 21, 2024, 12:12:09 am »
I'm currently spinning up my own version of this design and replacing the DC-DC converters with something a little cheaper.
Can someone who has built one of these measure the voltage and current draw from the output of each DC-DC converter with the displays lit to the maximum number of pixels by chance?
« Last Edit: May 21, 2024, 12:52:43 am by TERRA Operative »
  • Country: jp
« Reply #83 on: May 23, 2024, 09:28:46 am »
So, I've made my own spin of this board. I swapped out the expensive buck converters with cheaper options (still from TI) and optimised the layout somewhat.
I also spaced the two halves of the PCB so they can be easily cut apart with one of these. (Ignore the trace connecting the two sides, it's just to try to trick the PCB manufacturers into thinking it's not two separate designs....  ;D )
The BOM file is such that it should be able to be dropped into JLCPCB for assembly, I think... I haven't tried so let me know how you go...
It should all just work (I made no major changes besides the DC-DC converters) so take this as a Beta version until verified by someone.  :P
As for the displays, you can get them on Aliexpress, but JLCPCB has them in their catalogue for their assembly service too.
I plan to get a bunch made sometime soon-ish, so I'll report back once it's done.
« Last Edit: May 23, 2024, 09:54:12 am by TERRA Operative »
The following users thanked this post: rsjsouza, damien
