Author Topic: TLA614 Hard Drive crash  (Read 1978 times)
Offline EnforcerTopic starter
« on: October 25, 2020, 08:25:13 am »
I know it’s likely a long shot, but the drive on my TLA614 gave up the ghost. Does anyone know how to get ahold of the win 2000 recovery disk and the software to do a reinstall?
Thanks!
Offline nctnico
Re: TLA614 Hard Drive crash
« Reply #1 on: October 25, 2020, 08:48:32 am »
Windows 2000 images can be found using Google. The logic analyser software can be downloaded from Tektronix. This is also a good time to upgrade to an SSD (for example using an mSata to 44pin adapter).
Offline rvalente
  • Country: br
« Reply #2 on: October 26, 2020, 01:05:04 am »
Get a industrial grade ssd with the same ide interface, very common for pane pcs
« Reply #3 on: October 26, 2020, 09:09:48 am »
Thanks for the tips. I’ve gotten w2k installed. However, Tek doesn’t have the TLA 4.4 software available anymore and 5.1 won’t install. Anyone have any ideas? I extracted some of the drivers from the 5.1 installer but that’s as far as I got. Missing a pci bridge device and a usb device driver.
Offline nctnico
« Reply #4 on: October 26, 2020, 01:14:00 pm »
Send me a PM with your e-mail address. It seems I have version 4.4 and a patched version 5.5 which might install on the TLA614. I can send those using a file transfer service.
Offline gslick
« Reply #5 on: October 27, 2020, 12:40:26 am »
I have Tektronix Logic Analyzer Family Application Software, Version 4.4, part number 063-3487-03, CD-ROM.
I could create an image of that CD-ROM and upload it somewhere if that helps and if there aren't any other copies around.
Contents, around 400MB:
Z:\Release Notes.doc
Z:\CheckIt\Util7.exe
Z:\Documentation\AdobeReader60Install.exe
Z:\Documentation\PatGenVuReadMe.txt
Z:\Documentation\TLAVuReadMe.txt
Z:\Documentation\TLA Application Notes\A Digital Designers Guide to Signal Integrity Primer.PDF
Z:\Documentation\TLA Application Notes\Access to the Target Technical Brief - 52W_12479_1.pdf
Z:\Documentation\TLA Application Notes\Active Attenuator Probing Technical Brief - 52W_11237_0.pdf
Z:\Documentation\TLA Application Notes\Integrated Debug of Embedded Systems Technical Brief - 52W_1.pdf
Z:\Documentation\TLA Application Notes\Introduction to Logic Analysis Hardware Debug Tutorial - 52W.pdf
Z:\Documentation\TLA Application Notes\Logic Analyzer Dual Display Support Application Note - 52W_1.pdf
Z:\Documentation\TLA Application Notes\MagniVu Technical Brief - 52W_11192_1.pdfZ:\Documentation\TLA Application Notes\Pattern Generation Application Note - 52W_13770_0.pdf
Z:\Documentation\TLA Application Notes\PowerPC Digital Debug Solutions Application Note - 52W_15469.pdf
Z:\Documentation\TLA Application Notes\RapidIO Digital Debug Solutions Application Note - 5AW_16056.pdf
Z:\Documentation\TLA Application Notes\RapidIO Technical Brief - 5AW_15975_0.pdfZ:\Documentation\TLA Application Notes\Remote Control on the TLA Technical Brief - 52W_12145_1.pdf
Z:\Documentation\TLA Application Notes\Signal Integrity Debug Solutions Application Note - 52W_1462.pdf
Z:\Documentation\TLA Application Notes\TLA Advanced Triggering Technical Brief - 52W_11191_1.pdf
Z:\Documentation\TLA Application Notes\TLA Integrated Software Tools Technical Brief - 52W_12480_1.pdf
Z:\Documentation\TLA Application Notes\The Importance of Timing in a Logic Analyzer Application Not.pdf
Z:\Documentation\TLA Application Notes\Using Deep Memory Application Note - 52W_13153_2.pdf
Z:\Documentation\TLA Application Notes\XYZ's of Logic Analyzers Primer - 52W_14266_0.pdf
Z:\Documentation\Tektronix Partners\Smith Micro Software\CheckIt Manual.pdf
Z:\Documentation\Tektronix Partners\Smith Micro Software\CheckIt Troubleshooting Guide.pdf
Z:\Documentation\Tektronix Partners\SynaptiCAD\InstallSoftware.exe
Z:\Documentation\Tektronix Partners\SynaptiCAD\WaveFormerPro.pdf
Z:\DotNet Framework\Install Framework.exe
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfaraxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfchsxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfchtxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfcsyxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfdanxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfdeuxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfellxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfenuxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfespxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atffinxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atffraxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfhebxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfhunxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfitaxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfjpnxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfkorxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfnldxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfnorxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfplkxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfptbxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfrusxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfsvexx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atfthaxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atftrkxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\ati2drab.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\ati2evxx.ex_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\ati2mpab.sy_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atifont.co_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atii2kab.inf
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atiicdxx.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atiicdxx.sy_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atiicdxx.vx_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atiidtxx.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atiiiexx.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atiiprxx.ex_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atio2kab.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atipdlxx.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atipdsxx.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atiphexx.ex_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atippaxx.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atiptaxx.ex_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atipuixx.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atitvo32.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\ativcoxx.dl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmaraxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmaraxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmchsxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmchsxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmchtxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmchtxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmcsyxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmcsyxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmdanxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmdanxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmdeuxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmdeuxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmellxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmellxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmenuxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmenuxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmespxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmespxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmfinxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmfinxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmfraxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmfraxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmhebxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmhebxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmhunxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmhunxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmitaxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmitaxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmjpnxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmjpnxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmkorxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmkorxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmnldxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmnldxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmnorxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmnorxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmplkxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmplkxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmptbxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmptbxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmrusxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmrusxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmsvexx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmsvexx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmthaxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmthaxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmtrkxx.cn_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atmtrkxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atricdxx.df_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atridtxx.df_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.ar_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.chs
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.cht
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.cs_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.da_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.de_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.df_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.el_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.es_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.fi_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.fr_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.he_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.hu_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.it_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.jp_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.ko_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.nl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.no_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.pl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.pt_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.ru_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.sv_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.th_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atriprxx.tr_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.ar_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.chs
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.cht
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.cs_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.da_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.de_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.el_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.en_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.es_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.fi_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.fr_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.he_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.hu_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.it_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.jp_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.ko_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.nl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.no_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.pl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.pt_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.ru_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.sv_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.th_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atrpuixx.tr_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attaraxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attchsxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attchtxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attcsyxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attdanxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attdeuxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attellxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attenuxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attespxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attfinxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attfraxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atthebxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atthunxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attitaxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attjpnxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attkorxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attnldxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attnorxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attplkxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attptbxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attrusxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attsvexx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\attthaxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\atttrkxx.hl_
Z:\Drivers\TLA520X\ATI Rage Mobility PCI\oemdspif.dl_
Z:\Drivers\TLA520X\Front Panel\TekFPUsb.inf
Z:\Drivers\TLA520X\Front Panel\TekFPUsb.sys
Z:\Drivers\TLA520X\INF_Intel 82801DB ICH4\infinst_enu.exe
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\data1.cab
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\data1.hdr
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\data2.cab
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\delcabs.bat
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\iac97k4.sys
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\iac97u4.dll
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\ikernel.ex_
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\layout.bin
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\oemsetup.inf
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\setup.bmp
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\setup.exe
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\setup.ini
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\setup.inx
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\setup.iss
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\setuphlp.dll
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\setupnt4.dll
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\st_inst.ini
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\stac97.cat
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\stac97.inf
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\stac97.log
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\stac97.sys
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\stacconfig.exe
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\stfindcs.sys
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\stfndcsd.dll
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\stfndcsv.vxd
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\ich\wdm\setuphlp.dll
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\ich\wdm\stac97.cat
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\ich\wdm\stac97.inf
Z:\Drivers\TLA520X\Intel 82845G Audio-WDM\ich\wdm\stac97.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\ReadMe.txt
Z:\Drivers\TLA520X\Intel 82845G Graphics\autorun.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Install.cfg
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Setup.exe
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Setup.ini
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\data1.cab
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\data1.hdr
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\data2.cab
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\ikernel.ex_
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\layout.bin
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\setup.inx
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\setup.iss
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Support\SignTime.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Support\shpshftr.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\Vch.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\Vch.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a302.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a302.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a302.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a303.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a303.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a303.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a304.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a304.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a304.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a305.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a305.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a305.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a306.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a306.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a306.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a307.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a307.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a307.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a308.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a308.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a308.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a309.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a309.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a309.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a310.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a310.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a310.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a311.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a311.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a311.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a312.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a312.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\a312.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\hccutils.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\hkcmd.exe
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\i830mnt5.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmcoin.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmdd5.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmdev5.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmdnt5.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmgdev.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmgicd.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmkchw.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmnt5.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmnt5.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmrem.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmrnt5.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ialmsbw.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxcfg.exe
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxcpl.cpl
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxdev.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxdgps.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxdiag.exe
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxdo.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxeud.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhara.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxharb.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhchs.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhcht.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhcsy.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhdan.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhdeu.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhell.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxheng.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhenu.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhesp.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhfin.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhfra.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhfrc.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhheb.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhhun.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhita.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhjpn.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhk.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhkor.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhnld.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhnor.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhplk.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhptb.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhptg.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhrus.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhsve.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhtha.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxhtrk.lhp
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxpph.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrara.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrarb.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrchs.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrcht.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrcsy.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrdan.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrdeu.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrell.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxreng.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrenu.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxresp.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxress.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrfin.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrfra.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrfrc.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrheb.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrhun.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrita.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrjpn.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrkor.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrnld.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrnor.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrplk.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrptb.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrptg.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrrus.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrsve.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrtha.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxrtrk.lrc
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxsrvc.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\igfxtray.exe
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ikch8xx.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\ikch8xx.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\isb8xx.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\isb8xx.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\oemdspif.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\shpshftr.dll
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\vch.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\wa301a.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\wa301a.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\wa301a.sys
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\wa301b.cat
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\wa301b.inf
Z:\Drivers\TLA520X\Intel 82845G Graphics\Graphics\Win2000\wa301b.sys
Z:\Drivers\TLA520X\Lan 6.4C0735\Readme.txt
Z:\Drivers\TLA520X\Lan 6.4C0735\RelNotes.rtf
Z:\Drivers\TLA520X\Lan 6.4C0735\Setup.exe
Z:\Drivers\TLA520X\Lan 6.4C0735\license.rtf
Z:\Drivers\TLA520X\Lan 6.4C0735\v6.4_PRO2KXP_only.exe
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1028.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1030.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1031.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1033.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1034.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1035.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1036.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1040.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1041.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1042.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1043.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1044.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1046.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\1053.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\2052.mst
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\ANSMW2K.INF
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\ANSMXP.INF
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\ANSPW2K.INF
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\ANSPXP.INF
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\PROSet.exe
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\PROSet.msi
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\iansmsg.dll
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\iansw2k.cat
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\iansw2k.sys
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\ianswxp.cat
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\ianswxp.sys
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\s8023Dev.Reg
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\PROSet\WIN2K\vssver.scc
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\SETUP\SETUPBD\W98-XP32\NetInst.dll
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\SETUP\SETUPBD\W98-XP32\SetBDRes.dll
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\SETUP\SETUPBD\W98-XP32\SetupBD.exe
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\SETUP\SETUPBD\W98-XP32\SetupBD.ini
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\SETUP\SETUPBD\W98-XP32\vssver.scc
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\TOOLS\DIAG1000.EXE
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\TOOLS\IDADAPT.EXE
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\TOOLS\IDADAPT.TXT
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\TOOLS\diag100.exe
Z:\Drivers\TLA520X\Lan 6.4C0735\APPS\TOOLS\vssver.scc
Z:\Drivers\TLA520X\Lan 6.4C0735\MakeDisk\Make2KXP.bat
Z:\Drivers\TLA520X\Lan 6.4C0735\MakeDisk\vssver.scc
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WIN2K\PROUnstl.exe
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WIN2K\e100bmsg.dll
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WIN2K\e100bnt5.cat
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WIN2K\e100bnt5.din
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WIN2K\e100bnt5.inf
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WIN2K\e100bnt5.sys
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WIN2K\intelnic.dll
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WIN2K\vssver.scc
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WINXP32\PROUnstl.exe
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WINXP32\e100b325.cat
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WINXP32\e100b325.din
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WINXP32\e100b325.inf
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WINXP32\e100b325.sys
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WINXP32\e100bmsg.dll
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WINXP32\intelnic.dll
Z:\Drivers\TLA520X\Lan 6.4C0735\PRO100\WINXP32\vssver.scc
Z:\Drivers\TLA520X\PCI-VXI Bridge\vbd.inf
Z:\Drivers\TLA520X\PCI-VXI Bridge\vbd.sys
Z:\Drivers\TLA600\C&T 69000 video\CHIPSD5.DLL
Z:\Drivers\TLA600\C&T 69000 video\CHIPSDAN.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSDEU.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSDSP.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSDSP.ICO
Z:\Drivers\TLA600\C&T 69000 video\CHIPSESP.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSFIN.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSFRA.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSITA.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSJPN.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSM5.SYS
Z:\Drivers\TLA600\C&T 69000 video\CHIPSNLD.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSNON.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHIPSPTB.HLP
Z:\Drivers\TLA600\C&T 69000 video\CHPSPTRT.EXE
Z:\Drivers\TLA600\C&T 69000 video\CHPSTART.EXE
Z:\Drivers\TLA600\C&T 69000 video\CNTNTDSP.DAT
Z:\Drivers\TLA600\C&T 69000 video\CNTNTDSP.DLL
Z:\Drivers\TLA600\C&T 69000 video\DESC.TXT
Z:\Drivers\TLA600\C&T 69000 video\DISK1
Z:\Drivers\TLA600\C&T 69000 video\ENUCPRES.DLL
Z:\Drivers\TLA600\C&T 69000 video\INSTALL.TXT
Z:\Drivers\TLA600\C&T 69000 video\LICENSE.TXT
Z:\Drivers\TLA600\C&T 69000 video\OEMSETUP.INF
Z:\Drivers\TLA600\C&T 69000 video\SW.EXE
Z:\Drivers\TLA600\C&T 69000 video\TXTSETUP.OEM
Z:\Drivers\TLA600\C&T 69000 video\nt5s239.exe
Z:\Drivers\TLA600\Front Panel\TekFPUsb.inf
Z:\Drivers\TLA600\Front Panel\TekFPUsb.sys
Z:\Drivers\TLA600\PCI-ISA Bridge\ite.inf
Z:\Drivers\TLA600\PCI-VXI Bridge\vbd.inf
Z:\Drivers\TLA600\PCI-VXI Bridge\vbd.sys
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSD5.DLL
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSDAN.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSDEU.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSDSP.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSDSP.ICO
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSESP.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSFIN.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSFRA.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSITA.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSJPN.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSM5.SYS
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSNLD.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSNON.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHIPSPTB.HLP
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHPSPTRT.EXE
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CHPSTART.EXE
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CNTNTDSP.DAT
Z:\Drivers\TLA714_TLA720\C&T 69000 video\CNTNTDSP.DLL
Z:\Drivers\TLA714_TLA720\C&T 69000 video\DESC.TXT
Z:\Drivers\TLA714_TLA720\C&T 69000 video\DISK1
Z:\Drivers\TLA714_TLA720\C&T 69000 video\ENUCPRES.DLL
Z:\Drivers\TLA714_TLA720\C&T 69000 video\INSTALL.TXT
Z:\Drivers\TLA714_TLA720\C&T 69000 video\LICENSE.TXT
Z:\Drivers\TLA714_TLA720\C&T 69000 video\OEMSETUP.INF
Z:\Drivers\TLA714_TLA720\C&T 69000 video\SW.EXE
Z:\Drivers\TLA714_TLA720\C&T 69000 video\TXTSETUP.OEM
Z:\Drivers\TLA714_TLA720\C&T 69000 video\nt5s239.exe
Z:\Drivers\TLA714_TLA720\PCI-VXI Bridge\vbd.inf
Z:\Drivers\TLA714_TLA720\PCI-VXI Bridge\vbd.sys
Z:\Drivers\TLA715_TLA721\82815 Chipset\Readme.txt
Z:\Drivers\TLA715_TLA721\82815 Chipset\Setup.exe
Z:\Drivers\TLA715_TLA721\82815 Chipset\Setup.ini
Z:\Drivers\TLA715_TLA721\82815 Chipset\data1.cab
Z:\Drivers\TLA715_TLA721\82815 Chipset\data1.hdr
Z:\Drivers\TLA715_TLA721\82815 Chipset\data2.cab
Z:\Drivers\TLA715_TLA721\82815 Chipset\devlist.ini
Z:\Drivers\TLA715_TLA721\82815 Chipset\ikernel.ex_
Z:\Drivers\TLA715_TLA721\82815 Chipset\infupd.bmp
Z:\Drivers\TLA715_TLA721\82815 Chipset\layout.bin
Z:\Drivers\TLA715_TLA721\82815 Chipset\setup.inx
Z:\Drivers\TLA715_TLA721\82815 Chipset\setup.iss
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\815.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\830.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\850.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\850860.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\860.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\860b.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\almador.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\brookdal.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2aud.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2br.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2brm.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2core.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2corm.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2ide.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2idem.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2smb.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich2usb.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich3core.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich3corm.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich3ide.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich3idem.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich3smb.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\ich3usb.cat
Z:\Drivers\TLA715_TLA721\82815 Chipset\Win2000\p64h2.cat
Z:\Drivers\TLA715_TLA721\82815 Video\win2k_xpe66.exe
Z:\Drivers\TLA715_TLA721\Intel LANcard\Net82557.din
Z:\Drivers\TLA715_TLA721\Intel LANcard\PROUnstl.exe
Z:\Drivers\TLA715_TLA721\Intel LANcard\e100bnt5.sys
Z:\Drivers\TLA715_TLA721\Intel LANcard\intelnic.dll
Z:\Drivers\TLA715_TLA721\Intel LANcard\neti557x.inf
Z:\Drivers\TLA715_TLA721\Lynx3DM Video\SMI.CAT
Z:\Drivers\TLA715_TLA721\Lynx3DM Video\SMISETUP.INF
Z:\Drivers\TLA715_TLA721\Lynx3DM Video\release.txt
Z:\Drivers\TLA715_TLA721\Lynx3DM Video\smidisp.dll
Z:\Drivers\TLA715_TLA721\Lynx3DM Video\smimini.sys
Z:\Drivers\TLA715_TLA721\NetGear LANcard\FA511ND5.SYS
Z:\Drivers\TLA715_TLA721\NetGear LANcard\NETFA511.INF
Z:\Drivers\TLA715_TLA721\PCI-VXI Bridge\vbd.inf
Z:\Drivers\TLA715_TLA721\PCI-VXI Bridge\vbd.sys
Z:\Lynx3DM\DATA.TAG
Z:\Lynx3DM\SETUP.EXE
Z:\Lynx3DM\SETUP.INI
Z:\Lynx3DM\_INST32I.EX_
Z:\Lynx3DM\_ISDEL.EXE
Z:\Lynx3DM\_sys1.cab
Z:\Lynx3DM\_user1.cab
Z:\Lynx3DM\data1.cab
Z:\Lynx3DM\lang.dat
Z:\Lynx3DM\layout.bin
Z:\Lynx3DM\os.dat
Z:\Lynx3DM\setup.ins
Z:\Lynx3DM\setup.lid
Z:\Lynx3DM\smoem.ini
Z:\Lynx3DM\setupdir\0009\_SETUP.DLL
Z:\Macromedia\flashplayer6_winax.exe
Z:\Mouseware\MouseWareV9_76.exe
Z:\NI-GPIB-USB\AutoRun.exe
Z:\NI-GPIB-USB\AutoRun.inf
Z:\NI-GPIB-USB\FileLoc.ini
Z:\NI-GPIB-USB\Getting Started Documentation.exe
Z:\NI-GPIB-USB\JapaneseLicense.rtf
Z:\NI-GPIB-USB\License.rtf
Z:\NI-GPIB-USB\Patents.txt
Z:\NI-GPIB-USB\ReadMeJp.txt
Z:\NI-GPIB-USB\Readme.txt
Z:\NI-GPIB-USB\Setup.exe
Z:\NI-GPIB-USB\AutoRun\eagle.ico
Z:\NI-GPIB-USB\NI-488.2\EngSetupResDll.dll
Z:\NI-GPIB-USB\NI-488.2\InstMsi.Exe
Z:\NI-GPIB-USB\NI-488.2\InstMsiw.Exe
Z:\NI-GPIB-USB\NI-488.2\JapaneseLicense.rtf
Z:\NI-GPIB-USB\NI-488.2\License.rtf
Z:\NI-GPIB-USB\NI-488.2\merged.msi
Z:\NI-GPIB-USB\NI-488.2\niPie.exe
Z:\NI-GPIB-USB\NI-488.2\setup.exe
Z:\NI-GPIB-USB\NI-488.2\setup.ini
Z:\NI-GPIB-USB\NI-488.2\setupJpn.exe
Z:\NI-GPIB-USB\NI-488.2\setupJpn.ini
Z:\NI-GPIB-USB\NI-488.2\Parts\GPIBProvider\GPIB_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\GPIBProvider\GPIB_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\GPIBProvider\GPIB_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\GPIBProvider\GPIB_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\max.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\maxDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\maxFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\maxJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\DAQ_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\DAQ_Provider2.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\DAQ_Provider2Deu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\DAQ_Provider2Fra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\DAQ_Provider2Jpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\DAQ_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\DAQ_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\DAQ_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\GPIB_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\GPIB_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\GPIB_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\GPIB_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider2.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider2Deu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider2Fra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider2Jpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider3.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider3Deu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider3Fra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_Provider3Jpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IMAQ_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IVI_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IVI_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IVI_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\IVI_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\Motion_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\Motion_Provider2.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\Motion_Provider2Deu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\Motion_Provider2Fra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\Motion_Provider2Jpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\Motion_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\Motion_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\Motion_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\VISA_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\VISA_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\VISA_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\VISA_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\VXI_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\VXI_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\VXI_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\BaselineProviders\VXI_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\RemoteProvider\Remote_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\RemoteProvider\Remote_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\RemoteProvider\Remote_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\RemoteProvider\Remote_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\SoftwareProvider\Software_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\SoftwareProvider\Software_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\SoftwareProvider\Software_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\MAX\SoftwareProvider\Software_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\NI-488.2\EngToJapTran.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\NI-488.2\NI488.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\NISpy\NISpy.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\NISpy\NiSpy-Deu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\NISpy\NiSpy-Fra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\NISpy\NiSpy-Jpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\PAL\palSetup.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\PAL\palSetup_deu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\PAL\palSetup_fra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\PAL\palSetup_jpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISA\NI-VISA\NIvisa261.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\VISA\NI-VISA\Visa-Deu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISA\NI-VISA\Visa-Fra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISA\NI-VISA\Visa-Jpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISA\VisaServer\NIVISA-Server.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\VISA\VisaServer\VisaServ-Deu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISA\VisaServer\VisaServ-Fra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISA\VisaServer\VisaServ-Jpn.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISAProvider\VISA_Provider.msi
Z:\NI-GPIB-USB\NI-488.2\Parts\VISAProvider\VISA_ProviderDeu.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISAProvider\VISA_ProviderFra.mst
Z:\NI-GPIB-USB\NI-488.2\Parts\VISAProvider\VISA_ProviderJpn.mst
Z:\NI-GPIB-USB\NI-488.2\lang\niresdeu.dll
Z:\NI-GPIB-USB\NI-488.2\lang\niresfra.dll
Z:\NI-GPIB-USB\NI-488.2\lang\niresjpn.dll
Z:\NI-GPIB-USB\NI-488.2\transforms\merged0007.mst
Z:\NI-GPIB-USB\NI-488.2\transforms\merged0012.mst
Z:\NI-GPIB-USB\NI-488.2\transforms\merged0017.mst
Z:\NI-GPIB-USB\NI-488.2 Documentation\GPIB Analyzer User Manual.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\GPIB Hardware Guide.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Getting Started Card 1.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Getting Started Card 11.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Getting Started Card 12.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Getting Started Card 3.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Getting Started Card 4.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\NI-488.2 API Quick Reference Card.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\NI-488.2 User Manual.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Japanese\GPIB Hardware Guide Jpn.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Japanese\Getting Started Card 1.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Japanese\Getting Started Card 11.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Japanese\Getting Started Card 12.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Japanese\Getting Started Card 3.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Japanese\Getting Started Card 4.pdf
Z:\NI-GPIB-USB\NI-488.2 Documentation\Japanese\NI-488.2 API Quick Reference Card.pdf
Z:\Pattern Generator Application SW\Release Notes.doc
Z:\Pattern Generator Application SW\Setup.exe
Z:\Pattern Generator Application SW\Setup.ini
Z:\Pattern Generator Application SW\data1.cab
Z:\Pattern Generator Application SW\data1.hdr
Z:\Pattern Generator Application SW\data2.cab
Z:\Pattern Generator Application SW\ikernel.ex_
Z:\Pattern Generator Application SW\layout.bin
Z:\Pattern Generator Application SW\setup.bmp
Z:\Pattern Generator Application SW\setup.inx
Z:\PowerFlex\DATA.TAG
Z:\PowerFlex\SETUP.INI
Z:\PowerFlex\Setup.exe
Z:\PowerFlex\_INST32I.EX_
Z:\PowerFlex\_ISDel.exe
Z:\PowerFlex\_Setup.dll
Z:\PowerFlex\_sys1.cab
Z:\PowerFlex\_sys1.hdr
Z:\PowerFlex\_user1.cab
Z:\PowerFlex\_user1.hdr
Z:\PowerFlex\data1.cab
Z:\PowerFlex\data1.hdr
Z:\PowerFlex\lang.dat
Z:\PowerFlex\layout.bin
Z:\PowerFlex\os.dat
Z:\PowerFlex\setup.ins
Z:\PowerFlex\setup.lid
Z:\RecordNow MAX\HISTORY.BLD
Z:\RecordNow MAX\INS9XMSI.EXE
Z:\RecordNow MAX\INSNTMSI.EXE
Z:\RecordNow MAX\MyCDPro.msi
Z:\RecordNow MAX\Setup.exe
Z:\RecordNow MAX\Setup.ini
Z:\RecordNow MAX\pconfig.dcf
Z:\RecordNow MAX\px.ini
Z:\RecordNow MAX\readme.txt
Z:\RecordNow MAX\rnm_qsg.pdf
Z:\RecordNow MAX\DLA\DLA.msi
Z:\RecordNow MAX\DLA\HISTORY.BLD
Z:\RecordNow MAX\DLA\Setup.ini
Z:\RecordNow MAX\DLA\pconfig.dcf
Z:\RecordNow MAX\DLA\readme.txt
Z:\RecordNow MAX\DLA\UM\HISTORY.BLD
Z:\RecordNow MAX\DLA\UM\SGuard.msi
Z:\RecordNow MAX\DLA\UM\Setup.ini
Z:\RecordNow MAX\DLA\UM\banner.ini
Z:\RecordNow MAX\DLA\UM\pconfig.dcf
Z:\SnagIt\1-Introduction.avi
Z:\SnagIt\2-Basic_Image_Capture.avi
Z:\SnagIt\3-Preview_Window.avi
Z:\SnagIt\4-Profiles.avi
Z:\SnagIt\5-SnagIt_Editor.avi
Z:\SnagIt\CamPlay.exe
Z:\SnagIt\License.txt
Z:\SnagIt\Readme.txt
Z:\SnagIt\Setup.exe
Z:\SnagIt\SnagItGSG.pdf
Z:\SnagIt\Studio.txt
Z:\SnagIt\TSCC.exe
Z:\SnagIt\eireadme.txt
Z:\SnagIt\readme_video.txt
Z:\SnagIt\SnagItTour\SnagItTour.html
Z:\SnagIt\SnagItTour\SnagItTour.swf
Z:\SnagIt\SnagItTour\config.xml
Z:\SnagIt\SnagItTour\movies\basic_image_capture.swf
Z:\SnagIt\SnagItTour\movies\captureprofiles.swf
Z:\SnagIt\SnagItTour\movies\introduction.swf
Z:\SnagIt\SnagItTour\movies\preload.swf
Z:\SnagIt\SnagItTour\movies\previewwindow.swf
Z:\SnagIt\SnagItTour\movies\snagiteditor.swf
Z:\TLA Application SW\DATA.TAG
Z:\TLA Application SW\Release Notes.doc
Z:\TLA Application SW\SETUP.INI
Z:\TLA Application SW\Setup.bmp
Z:\TLA Application SW\Setup.exe
Z:\TLA Application SW\_INST32I.EX_
Z:\TLA Application SW\_ISDel.exe
Z:\TLA Application SW\_Setup.dll
Z:\TLA Application SW\_sys1.cab
Z:\TLA Application SW\_sys1.hdr
Z:\TLA Application SW\_user1.cab
Z:\TLA Application SW\_user1.hdr
Z:\TLA Application SW\data1.cab
Z:\TLA Application SW\data1.hdr
Z:\TLA Application SW\lang.dat
Z:\TLA Application SW\layout.bin
Z:\TLA Application SW\os.dat
Z:\TLA Application SW\setup.ins
Z:\TLA Application SW\setup.lid
Z:\TLA Performance Verification\Logic Analyzer PV\AUTORUN.INF
Z:\TLA Performance Verification\Logic Analyzer PV\DATA.TAG
Z:\TLA Performance Verification\Logic Analyzer PV\SETUP.BMP
Z:\TLA Performance Verification\Logic Analyzer PV\SETUP.INI
Z:\TLA Performance Verification\Logic Analyzer PV\Setup.exe
Z:\TLA Performance Verification\Logic Analyzer PV\_ISDel.exe
Z:\TLA Performance Verification\Logic Analyzer PV\_Setup.dll
Z:\TLA Performance Verification\Logic Analyzer PV\_inst32i.ex_
Z:\TLA Performance Verification\Logic Analyzer PV\_sys1.cab
Z:\TLA Performance Verification\Logic Analyzer PV\_sys1.hdr
Z:\TLA Performance Verification\Logic Analyzer PV\_user1.cab
Z:\TLA Performance Verification\Logic Analyzer PV\_user1.hdr
Z:\TLA Performance Verification\Logic Analyzer PV\data1.cab
Z:\TLA Performance Verification\Logic Analyzer PV\data1.hdr
Z:\TLA Performance Verification\Logic Analyzer PV\lang.dat
Z:\TLA Performance Verification\Logic Analyzer PV\layout.bin
Z:\TLA Performance Verification\Logic Analyzer PV\os.dat
Z:\TLA Performance Verification\Logic Analyzer PV\setup.ins
Z:\TLA Performance Verification\Logic Analyzer PV\setup.lid
Z:\TLA Performance Verification\Pattern Generator PV\DATA.TAG
Z:\TLA Performance Verification\Pattern Generator PV\SETUP.BMP
Z:\TLA Performance Verification\Pattern Generator PV\SETUP.INI
Z:\TLA Performance Verification\Pattern Generator PV\Setup.exe
Z:\TLA Performance Verification\Pattern Generator PV\_ISDel.exe
Z:\TLA Performance Verification\Pattern Generator PV\_Setup.dll
Z:\TLA Performance Verification\Pattern Generator PV\_inst32i.ex_
Z:\TLA Performance Verification\Pattern Generator PV\_sys1.cab
Z:\TLA Performance Verification\Pattern Generator PV\_sys1.hdr
Z:\TLA Performance Verification\Pattern Generator PV\_user1.cab
Z:\TLA Performance Verification\Pattern Generator PV\_user1.hdr
Z:\TLA Performance Verification\Pattern Generator PV\data1.cab
Z:\TLA Performance Verification\Pattern Generator PV\data1.hdr
Z:\TLA Performance Verification\Pattern Generator PV\lang.dat
Z:\TLA Performance Verification\Pattern Generator PV\layout.bin
Z:\TLA Performance Verification\Pattern Generator PV\os.dat
Z:\TLA Performance Verification\Pattern Generator PV\setup.ins
Z:\TLA Performance Verification\Pattern Generator PV\setup.lid
Z:\TLACAL\ADJ_PROC.doc
Z:\TLACAL\FIXTURE_CONNECTION.doc
Z:\TLACAL\PERF_VER.doc
Z:\TLACAL\ReleaseNotes.doc
Z:\TLACAL\Setup.exe
Z:\TLACAL\Setup.ini
Z:\TLACAL\data1.cab
Z:\TLACAL\data1.hdr
Z:\TLACAL\data2.cab
Z:\TLACAL\ikernel.ex_
Z:\TLACAL\layout.bin
Z:\TLACAL\setup.inx
« Reply #6 on: October 27, 2020, 02:15:40 am »
Nctnico got me the application, however it is missing the drivers. It looks like your cd listing actually has them. If you wouldn’t mind making an ISO, I would appreciate it! Also, huge thanks to everyone helping out with this!
« Reply #7 on: October 28, 2020, 05:35:06 am »
Have the system up and running on do with SW 5.6. Thank you to gslick and nctnico! I have the max option for the 614 of 200mhz and 256k depth. I see the 62x series start with a depth of 1mb. The data sheet mentions 2mb but I don’t see an option for that. Is the hardware different between the 62x and 61x? Or is this possibly a hidden option that can be enabled?
The following users thanked this post: nctnico
Offline gslick
« Reply #8 on: October 28, 2020, 06:20:42 pm »
The difference between the TLA61x series (64 K depth, options for up to 256 K depth) and the TLA62x series (1 M depth) is probably similar to the difference between the TLA7Lx module series (32 K depth, options for up to 128 K depth) and the TLA7Mx module series (512 K depth).
The higher series might use the same number of sample memory devices on the PCBs, but devices that are 4 times more dense, so there would be no software only option to upgrade from the TLA61x series 256 K depth to the TLA62x series 1 M depth.
If I got curious enough I could open up a TLA7L4 and a TLA7M4 for a quick memory device comparison. I don't have a TLA61x or TLA62x series.
« Reply #9 on: November 09, 2020, 06:55:50 pm »
I bought a TLA624 real cheap as I needed more state samples. Turns out the only difference in the boards is the sample memories being 4x more dense as you had speculated. I do have a weirdness with the 624 though. I have the 1Meg depth but I can only sample at 100mhz. The application for unlocking features says the 200mhz was an option but the sticker on the back says that it should already have 200mhz. There is no key code cause the 624 were only 1M 200mhz. Any idea on what I can do to rectify that?
Offline gslick
« Reply #10 on: November 10, 2020, 09:48:52 pm »
Do you have the "OpenChoice Talker Listener" installed in the TekVISA folder on your TLA624? If you do, can you start it up and connect to the analyzer instrument and then try issuing these queries:
SYST:CONF:DEPTH?
SYST:CONF:MAX:DEPTH?
SYST:CONF:SPEED?
SYST:CONF:MAX:SPEED?
If the reported current values are less than reported max values then you can use these commands to set the current values to the max values:
SYST:CONF:DEPTH <DEPTH>
SYST:CONF:SPEED <SPEED>
To enable the modification of the values you first need to to use this command, where <VERSION> is the firmware version reported in response to an *IDN? query:
SYST:PASS:INST:PASS "PitBull<VERSION>"
And after modifying the values you need to use this command for the modified values to take effect, where <TIME> is the current Unix timestamp value, for example from https://www.unixtimestamp.com/
SYST:PASS:INST:UPD <TIME>
If the battery in the NVRAM chip is dead the speed and depth changes may be lost and revert to their lowest option values when the analyzer is powered off.
More details can be found in this thread:
https://www.eevblog.com/forum/testgear/tla-hacks-)/msg470705/#msg470705
« Last Edit: November 10, 2020, 09:55:01 pm by gslick »
The following users thanked this post: Enforcer
« Reply #11 on: November 11, 2020, 01:59:29 am »
That worked beautifully!
Offline gslick
« Reply #12 on: November 01, 2023, 10:23:31 pm »
Someone asked me about this again so I finally got around to uploading a copy here:
https://archive.org/details/Tektronix_TLA-44_063-3487-03_Disc1_Disc2
