Author Topic: SOLVED  (Read 1798 times)
Offline 001Topic starter
  • Country: aq
SOLVED
« on: December 14, 2018, 04:17:40 pm »
Sorry I was fooled with english name of neon bulbs   |O
Thanx for help
« Last Edit: December 15, 2018, 02:02:49 pm by 001 »
Offline JimRemington
Re: What this unit do?
« Reply #1 on: December 14, 2018, 04:29:05 pm »
It is a power supply for discharge tubes.
The following users thanked this post: 001
  • Country: aq
« Reply #2 on: December 14, 2018, 04:30:04 pm »
discharge tubes?
why tubes charged?  :-//
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #3 on: December 14, 2018, 05:18:49 pm »
I think this is an issue with non-native english trying to understand the terminology.
A discharge tube is a category of lighting, the most common being the High Intensity Discharge lamps and neon tubes:
There are a number of variants and the device you linked to is supposed to be a somewhat universal power supply for them.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
  • Country: aq
« Reply #4 on: December 14, 2018, 05:23:51 pm »
Thanck You!
Does it mean what it is common  variable HV power supplies?
Offline coromonadalix
« Reply #5 on: December 14, 2018, 10:13:10 pm »
001  you have the manual available read it ...    https://www.bkprecision.com/products/power-supplies/1511-digital-discharge-tube-power-supply.html#docsoft
You post tons of questions here and there, you should be able to do some personal search "Google is our friend"  and have your responses before posting something here.
You seems to be a thread starter in many many things ?
  • Country: aq
« Reply #6 on: December 15, 2018, 03:20:55 am »
It looks wery small for its specs and I was fooled with english name of neon bulbs  :-//
Thanx for help
