Author Topic: HP Logic Analyzer Inverse Assemblers  (Read 58170 times)
Offline Hamster
Re: HP Logic Analyzer Inverse Assemblers
« Reply #175 on: July 15, 2024, 08:48:34 pm »
most if all the information is in this thread, however, some processors require pre-processors to work ( z80, etc ) , you can't just hook up the LA and then use the IA(s).
all the documentation for how to compile the IA for new version Systems have been posted.
i dont think i have ever seen anything that shows cpu to cpu layout.
Arcade Board Repair Guru.  [ twitch: HammysHangout , youTube: Hammy Builds ]
Offline go4retro
« Reply #176 on: July 16, 2024, 05:26:10 am »
My goal was to design some adapters that didn't fall into the trap of one of the links earlier in the thread:
https://pcbjunkie.net/index.php/logic-analyzer-adapters/
Obviously, his adapter for the Z80 lacks all the buffering, but even his 6502 adapter (which would not have needed any pre-processing, according to the current thread) uses the wrong pin mappings.
And, by looking at a few mappings in a single place, I might be able to deduce how best to create a mapping for a CPU not already supported (the TI ones in the cc-40/74/95 come to mind)
Jim
