Author Topic: HP ET0004 Variable AC Power supply  (Read 779 times)
Offline jseefriedTopic starter
« on: September 09, 2022, 09:35:59 pm »
Does anyone have a manual for this vintage variac? It looks similar to a 431b power meter case style with the knob mounted on the top case. So around 1970s vintage. However I cannot locate in in the hparchive catalogs. Thank you.
Online srb1954
  • Retired Electronics Design Engineer
Re: HP ET0004 Variable AC Power supply
« Reply #1 on: September 09, 2022, 09:58:56 pm »
The ET model number prefix indicates that it is an HP internal production test gear item. You will be very lucky if you ever find any published information on it.
