I want to turn my oscilloscope into a Vectrex game. Like usual I blundered forward and built myself a scopetrex, without bothering to check to see if my oscilloscope had a Z-axis input. It does not!
So, next step, I want to see if I can modify my oscilloscope, a BK Precision 2120B, to add Z-axis input. I think a binary input (all-on / all-off) is probably sufficient. The scopetrex just needs to be able to blank the electron beam while moving between objects in the display. I found the schematic for a BK 2160, which does support Z-axis input, and I found the schematic for my BK 2120B, which does not. Schematic snippets are attached below. My scope lacks the Z-axis circuit, R801, R804, D807, Q802.
So someone please vet me on this approach. All I need to do is add a PNP transistor, base resistor, and a pull up, and I ought to be good. The choice of transistor probably isn't even all that critical -- just something that can handle 24V at about 10mA.
Transistors I have easily laying around are the 2N3906 and MPSA92. Either ought to do?
Scott
