David - thanks again for the article - the circuit diagrams and description do help - but I'm finding that the circuit diagrams are "illustrative" but not "representative"!! For example, the way the input/AC coupling/switch is connected on the PCB is different than shown on the circuit diagram (same function, different placement and components)! Starting to re-draw from the PCB... With all the really important bits in the sealed hybrid module there is only so much to reverse engineer, though.
artag - thanks for offer, I may ask for some DC measurements?! Right now I can't confirm the "1V ohms ref" is correct - looks like mine might be off (like 0.5V). Since this voltage is apparently derived from a single voltage divider chain, if all the Vrefs are off, it could potentially explain my "-----" overflow displays? Apart from the lack of schematic, this beast has 3 ground refs (batt, analog, digital) complicating measurements (and figuring which ground is where on the PCB)!!!
The PCB and user manual all caution against static damage, and although my experience has been good relative to old electronics and static damage, it's a worry that the hybrid module might be "blown"... The fact the digital portion appears to be working to some extent (scans and displays all digits (with dashes)) is tantalizing, though.
