Ok I just set this up and I noticed that the name "Audio_Analyzer" wasn't correct.
If you run, say FR_v2_B.vxe then you'll see this:
From that image you can see that VEE is looking for an instrument called "Audio Analyzer" - Note the space not an underscore between Audio & Analyzer
So go into the IO Configuration tool in the start menu:
This window will come up:
Right click "My Configuration" and then "Add Instruments"
Enter the instrument information - You'll use 28 instead of 8 in the address and set the name to "Audio Analyzer". Click OK:
It should look like this now (with the right GPIB Address):
Now this bit is
Important - You need to click the save icon to save this configuration:
And now you can run the VXE:
TonyG
