Time ago I tried to tinker probes for a Tek 224 portable scope from scrapped Tek probes as the 224 does not have BNC inputs.
I can confirm that the probe cables are not standard coax, it had at least been difficult to solder.
On a low bandwidth scope possibly less critical, but at 100's of MHz, I would expect signal integrity problems.
