Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Tenma 72-10480 (Korad KA3003D) power supply - noisy fan
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tenma 72-10480 (Korad KA3003D) power supply - noisy fan (Read 2846 times)
mrchen
Newbie
Country:
on:
September 09, 2016, 08:37:59 pm »
I am trying to make my Tenma 72-10480 power supply more quiet. Without any load the fan is on and can be annoying. I was going to add a little circuit with a NTC thermistor and a Attiny microcontroller to control the fan with PWM depending on the temperature. But when I opened the case I found a thermistor is already there. Nevertheless the fan speed does not change at all when I heated the thermistor with a hair dryer. I suspected a faulty thermisor but it tested fine.
One might think that the fan runs at constant speed and is not controlled, but that's not the case. There is a thermal fuse inside the main power transformer and it is connected to the main board. When I disconnect it (simulating a blown fuse) the fan suddenly starts running faster. Reconnecting it slows the fan down again.
I am at a loss here - why is the temperature of the thermistor is ignored by the fan control logic? Any suggestions / advice would be appreciated. My unit is about 8 months old and it is free from the problem that Dave described. I also wondered if I got a faulty unit. If someone owns the same / similar model and is willing to open it and test the NTC thermistor / fan speed with a hair dryer that would be appreciated too.
I enclose a photo with the NTC thermistor marked.
Thank you
Logged
euzer
Contributor
Re: Tenma 72-10480 (Korad KA3003D) power supply - noisy fan
Reply #1 on:
July 02, 2018, 10:08:27 am »
With the output turned off, the fan on our 72-10480 idles away, but every 15 to 45 seconds suddenly ramps the fan on to a faster speed for a second or so, which is quite annoying.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
