Hello everybody,
I’m the designer of the hardware interface offered in the mentioned auction.
First of all I’d like to thank all the Forum users who allow me to learn new things every day.
Let me take the occasion to share with you some thoughts.
I didn’t invent anything, if not the implementation of the board on the PCB, in order to make it more easily usable
without the need of disassembling the oscilloscope.
IMPORTANT:
1) This board accesses a “Control Port” which has not been implemented for the final users,
but for the debug of the oscilloscopes in Tektronix and in distributors.
2) For various reasons, it’s much better to NOT leave it plugged into the oscilloscope (you can plug it of just with 2 screws).
3) “RTS-CTS Handshaking” guarantees security of transferred data, so it’s better using it with the following steps.
PROCEDURE (step by step in this order):
Plug the interface, connect it internally to Opt.013, connect RS232 cable to the PC, power on the PC, power on the oscilloscope,
use it and then you can restore Opt.013 interface.
POSSIBLE ERROR:
If you don’t connect serial cable or you don’t power on the PC, the oscilloscope will stay, AS EXPECTED,
locked, waiting for the communication on the “Console Port”!
This is exactly what happened to "Tantratron" and the reason for his complaint.
Thanks to everybody and to the dozens of people who appreciated my little work.
Maurizio
