Couldn't find mention of one on the forum so it's appropriate I share some pics.
Front
Rear
Top
Note the SMA spanner screwed to the chassis for the rigid plumbing.
Top under PCB
Hinged PCB swung away.....still connected.
Inside rear
Bottom
What appears to be a cavity oscillator take a large amount of the space in the enclosure.
It appears fully functional.
Last Cal 2005.
This unit has option 003 installed....Reverse power protection. It's a small self contained module seen on the right of Bottom image.
All that was needed was some sticker residue cleaning and the frequency range knob grub screws tightened.
Manual:
www.ue.eti.pg.gda.pl/~bpa/lab_klb/pdfs/08654b_manual.pdf18 Mb
Other than the MHz range selected there is no accurate display of the output frequency so a counter need be attached for accurate settings. There are/is some adjustment available for signal amplitude and user nulling for the moving coil meter.
A screenshot @ -3dB point of my SDS2304X. (~360 MHz)
