Author Topic: Gossen Metrahit 28S  (Read 8861 times)
Offline LunasixTopic starter
Gossen Metrahit 28S
« on: January 19, 2014, 11:35:57 am »
As another topic presents a Metrahit 25S, here is the 28S, for comparison.
The following users thanked this post: horo
Online BravoV
  • +++ ATH1
Re: Gossen Metrahit 28S
« Reply #1 on: January 19, 2014, 11:41:43 am »
Wow ... quite surprise to see that hanging 2 Mhz crystal without any firm support, and just relying on it's two soldered pins.
Not a very convincing for long term reliability against mechanical vibration, isn't it ?
Is it new ?
« Last Edit: January 19, 2014, 11:44:35 am by BravoV »
« Reply #2 on: January 19, 2014, 11:48:35 am »
That really should have a tiny double sided tape hold down. Better than the usual hot snot or silicone, and just as reliable.
Online BravoV
  • +++ ATH1
« Reply #3 on: January 19, 2014, 11:50:40 am »
Although unlikely with this battery/low power circuit, what if the big ic below it heated up ?
Still a poor design imo, especially for this kind of pricey meter.
Offline Wytnucls
« Reply #4 on: January 19, 2014, 11:55:13 am »
The meter is discontinued. This particular one has a March 2002 calibration certificate.
They age quite well, as long as they are kept in their rubber holsters.
My 26S from 2006 looks brand new too.
Most of the crystals on these meters are free standing. Doesn't seem to affect reliability.
« Last Edit: January 19, 2014, 12:03:07 pm by Wytnucls »
Offline robert_
« Reply #5 on: April 24, 2017, 04:22:48 pm »
Sadly calibration requires some software that only GMC seems to have. As far as i know, there is no possibility for stand-alone calibration.
It is done over the bidirectional IR port.
Oh, i just saw it actually is availible for sale at just around 4.5k. (Gossen Metrawatt Z211F)
I really wonder why that piece of crusty old software has not yet been umm, liberated or reverse engineered in some way.
If there is a installation file floating around, patching out that licence file check probably isnt too hard...
Only other problem is it requires some pretty pricey Fluke calibrator (well, you do need some pretty pricey hardware to calibrate a 0.025% multimeter after all) to do anything productive.
« Last Edit: April 24, 2017, 04:42:19 pm by robert_ »
Online coromonadalix
« Reply #6 on: April 24, 2017, 09:06:18 pm »
Holly !$!%$^^   that's not fun at all   :(  unless finding a leaked iso     i'm in no luck
There a demo at Gossen but it wont simulate the 28S  ...
« Last Edit: April 25, 2017, 01:36:59 am by coromonadalix »
Offline robert_
« Reply #7 on: April 25, 2017, 01:37:09 pm »
All that still wont help you unless you find a supported fluke 55xx calibrator to put that software to use.
You need some suitably accurate multifunction calibrator anyway. Manual calibration using a standard cell, KVD and loads of reference resistors and other things you also would need to have in the first place hasnt been a thing for many, many years.
Same thing with Fluke and all others. Everything a bit beyond really crappy 3 1/2 digit cheapies with a single trimpot has been software cal (using some all in one calibrator) only in the last 20 years.
So yes, you would need to have it calibrated at some cal lab, even though its expensive.
« Reply #8 on: May 04, 2017, 02:44:23 am »
the cpus are
tmp87ps64f   otp cpu,  the one with the fw version, i have a 1.52 ??
gmcad30 under the crystal,  maybe a custom one ??
hd61602   lcd driver  as shown
« Last Edit: May 09, 2017, 09:13:28 pm by coromonadalix »
Offline DrGEM
  • Country: md
« Reply #9 on: August 06, 2022, 09:16:08 am »
There is a device after oxidation of batteries and broken wires. Can anyone at hand suggest the correct location of the charging wires and batteries. Thanks1558978-0
« Reply #10 on: April 13, 2024, 04:29:37 pm »
late to reply
The calibration SW can be bought for a hefty price,  but as written, you need cal equipment connected to it ...
have a new puppy
v1.52 ??
here's my wiring (attached pictures)
since mine has black  dial overlay   is it more recent ??? or older  vs the green one    sn  is LAXXXX
no hanging crystal
and the charging port plug  has a nut ??
« Last Edit: April 13, 2024, 04:45:33 pm by coromonadalix »
