Alternative Solutions: If you're unable to get the integrated printer working, consider using an external thermal printer. Zebra and TSC offer reliable thermal printers that could serve as excellent alternatives. They are compatible with a wide range of software and hardware setups. Sunavin offers various models of Zebra and TSC printers, which you can explore at .
Alternative solutions? Spam?
How rude of dmderev to promote his own company when he wants a solution.
Can you replace it without modification? Are you making the exact same thing? If you are selling a "receipt printer", you are misguided.
Perhaps "activation" means "initialization". I think, lecroy's printer even if recognized as a common printer, cannot print with generic software because of non-standard initialization and other commands. Perhaps it will only work with the lecroy software on the 7200A.
The printer is probably modular and connected via USB.
It is possible to disassemble the printer module and find the solution from the chip inside, or from the USB VID/PID. Maybe it will work if you change the driver?
