Author Topic: HP 8559A repair  (Read 4371 times)
Offline idpromnutTopic starter
HP 8559A repair
« on: December 28, 2014, 04:02:38 am »
Several months ago I picked up an HP 8559A (with HP 853A display) for probably more than I should have. It needed a bit of work (there were a few broken wires in the SA module) and there is still an intermittent gremlin in the display power supply. The major thing that I liked about it and why I picked it up was the wide-band capabilities, 0.01 to 21GHz (in 6 bands).
Of course when I was testing it out, I actually run into a problem; only the first band (from 0.01 to 3GHz) worked and all the other bands displayed the same 3GHz band. I had put this problem aside since I didn't need anything higher than 3GHz for the moment. Today I decided to have another crack at trying to fix it. Looking at the service manual for the thing, I started working my way back form the front panel switches. They all tested out OK and the correct signals were being passed back into the frequency band selection board (A7). I pulled that board out and had closer look. That is when I found the problem: 2 "crushed" op-amps. They were most likely shorted out. These were used to adjust the YTO's driver for the higher than 3GHz frequency bands. The SA must have taken quite a knock to have done that!
Re: HP 8559A repair
« Reply #1 on: December 28, 2014, 04:40:44 am »
And did a  :-/O fix it ?
Re: HP 8559A repair
« Reply #2 on: December 28, 2014, 04:43:04 am »
A careful application of a leverage device (screwdriver) seems to have done the trick :) At least I can measure signals up in the 4.5GHz range now, which is better than before.
Re: HP 8559A repair
« Reply #3 on: December 28, 2014, 04:52:01 am »
Well you've a little way to go to 21 G  :o but thats gotto make you feel better.
I've allways been too :scared: to chase anyting like this for fear that you'd need another to fix it.  :palm:
Re: HP 8559A repair
« Reply #4 on: December 28, 2014, 02:18:13 pm »
The crazy thing was that it was sold "as-is" but the guy had said that it had been in good working condition when he had been using it a while back.  :palm:  It looks like those two op-amps were the result of some shock to the side of the unit (perhaps even in shipping) but I hadn't opened up the unit that much when I got it, and there were no pictures of the inside of the unit before I bought it.
