Author Topic: Identify and fix the oscilloscope probe  (Read 1384 times)
Offline 17_29bisTopic starter
« on: February 28, 2018, 12:10:39 am »
Hello,
I would really appreciate some help in identifying the oscilloscope probe that I would like to fix. There a problem with the 1:10 switch. Sometimes it creates a short (when the switch is moved from one position to another)  and then the resistance between the tip and the ground is 0.  So, I would want to know 2 things: what kind of probe is this  and how its body can be disassembled.  Here is some pictures:
Offline tautech
Re: Identify and fix the oscilloscope probe
« Reply #1 on: February 28, 2018, 12:16:17 am »
Try unscrewing the tip after which the sleeve behind it can slide off and then maybe all remaining slid back through the handle.
The following users thanked this post: vk6zgo
« Reply #2 on: February 28, 2018, 12:38:19 am »
Oh, thanks, indeed I could unscrew the tip but nothing is moving or sliding. May be the switch  itself should be removed  first? I also found a text on the probe saying "Made in Germany".
EDIT: looks like this is a TESTEC probe.
« Last Edit: February 28, 2018, 12:41:37 am by 17_29bis »
