Author Topic: LaPOD: Low cost Logic Analyzer probe for MSO5k, DHO900 and more!  (Read 20241 times)
Offline Electro Fan
Re: LaPOD: Low cost Logic Analyzer probe for MSO5k, DHO900 and more!
« Reply #150 on: April 08, 2024, 03:43:44 am »
Have you made one of these yet? I'd be very interested to see one.
Me too :p
LOL
oliv3r you do great work  :-+ :-+
Offline Songhua
  • Country: cn
« Reply #151 on: June 08, 2024, 10:59:01 am »
Now it's June 2024, have you made one?
Expect to see a real-working one.
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline maxora
  • Country: lk
« Reply #152 on: August 14, 2024, 03:50:18 pm »
Hi Guys,
So I made the thing. (POD_LMH7324 and Mini_HDMI_Breakout)
I ordered the PCBs and parts, and soldered by hand.
Checked for any dry joints or bridges. Didn't find any issues.
2339173-0
However, when I connected the probe to the scope, it did not work at all. I also noticed that the LMH7324 is getting hot.
So I started checking the connections and noticed that some pins are shorting out only when the HDMI cable is plugged to both PCBs.
To narrow-down the issue, I connected a HDMI header and a mini HDMI header (not soldered to the PCBs) and started checking the connections between two ends.
And that's when I noticed that the pins of the mini HDMI connector (Type C) are not in the same order as the HDMI connector (Type A).
But in the mini_hdmi_breakout PCB, the pins are in the same order as the Type-A header.
(The cable I used is a high speed HDMI cable with Ethernet)
I think someone else also should test the pin connections and confirm this. (just to make sure...)
And this is the pin order I got with my test. (Sorry about the messy image. I am too lazy to make it pretty...  :=\ )
2339169-1
There was no connection on pin 17 of mini HDMI connector. Not sure why though...
However, I think the HDMI breakout board should work fine. So I am going to order the PCBs for that.
« Last Edit: August 14, 2024, 04:00:15 pm by maxora »
The following users thanked this post: Songhua
Offline Songhua
  • Country: cn
« Reply #153 on: August 14, 2024, 08:59:05 pm »
I'm very happy to see someone finally made an actual one.
I read that you had problems with the pins.
Did you fix it? Now. Please keep updating in this post. Appreciate your comments!
