Twice today when unscrewing some coax from my reflection bridge, I got what felt like a nasty little rf burn under my wedding ring. The coax is hooked to an antenna outside and I was tracing from 1 - 30Mhz. If it isn't the TG, I guess maybe static on the antenna? It wasn't a shock like you would get in sox across a floor when touching a radiator, It was more like a circular burn feeling under my ring. Gets my attention, no harm done. Possible? I've had RF burns from my 2KW amp, this felt like a low-level version. Hands were damp both times.
If not the TG, then I have to figure a way to ground that antenna before I blow my SA front end.
Thoughts?
Jerry
