Yeah, that's the one. Mine tested almost no capacitance so I think they dried out or something.
I received the Mouser order this morning and just finished replacing the A1C2 caps in three 5335A's, and removing and testing one from my parts hulk.
I installed 105C 180uf @ 25V caps.
I tested the old ones that I removed and found the following:
All were Sprague 672D 100uf @ 15V rated at 105C
A1C2 from SN 2152A024xx tested @ ~ 50pf with a date code of 8121H
A1C2 from SN 2424A061xx tested @ ~620pf with a date code of 8337H
A1C2 from SN 2448A066xx tested @ ~110pf with a date code of 8426H1
A1C2 from SN 2820A120xx tested @ ~143pf with a date code of 8812H
With the two that you tested and found bad, I think I'd go out on a limb here and state that it would be a safe bet to automatically replace A1C2 in any 5335A that crossed your path.
Thanks for your post that brought these to my attention!
I just pulled A1C2 from my parts hulk and added it to the above list. It's even worse than the other three.
WoD
