Author Topic: Rigol DS1102E vs DS1054Z  (Read 6561 times)
Offline AndrewNormanTopic starter
« on: October 28, 2016, 12:35:30 pm »
I am currently in the market for a new scope. I trained using Analog ones / HP first gen digital scopes in the early 90s.
Now I am looking at getting one for hobby usages and am stuck looking at 2 of the Rigol scopes.
https://www.rigol-uk.co.uk/Rigol-DS1102E-Digital-Oscilloscope-p/ds1102e.htm#.WBMu9y0rJhE
https://www.rigol-uk.co.uk/Rigol-DS1054Z-Digital-Oscilloscope-p/ds1054z.htm#.WBNEJy0rJhF
My usage, initially (and probably for the next few years) is for 1-16Mhz Arduino logic circuit creation and debugging simple analog/digital circuits (think timers / amps / motor control boards / switch mode power supplys for Nixie tubes etc).
I can afford around the £350 mark, but I would appriciate any suggestions or recommendations around which one would suit my usage.
Regards
Andrew
Offline nugglix
Re: Rigol DS1102E vs DS1054Z
« Reply #1 on: October 28, 2016, 12:37:28 pm »
There are a lot of "I want a scope" threads around here.
Just have a look.
Offline Fungus
« Reply #2 on: October 28, 2016, 12:51:05 pm »
The DS1054Z is a LOT better for that sort of work.
More channels, serial decoders, bigger screen, lots more features, etc.
It can easily be unlocked to 100MHz so don't worry about that difference.
« Last Edit: October 28, 2016, 01:29:28 pm by Fungus »
Online wraper
  • Country: lv
« Reply #3 on: October 28, 2016, 01:00:39 pm »
DS1102E  is completely obsolete model.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: October 28, 2016, 01:35:59 pm »
definitely DS1054Z
« Reply #5 on: October 28, 2016, 01:38:51 pm »
Just have a look.
I did and managed to get completely confused by all the information flying around ... but they managed to get me narrowed down to the two mentioned above.
I didn't know that ... thanks for the heads-up
definitely DS1054Z
Sounds like I will get a DS1054Z then :)
Thanks Guys
Offline picandmix
« Reply #6 on: October 28, 2016, 01:55:18 pm »
Just make sure you buy from an authorised dealer, not the ebay cheapies where any warranty work may mean sending  it back to China.
http://www.rigol.eu/how-to-buy/
The following users thanked this post: AndrewNorman
