Author Topic: Aritsu VNA-DL 1-8800 MHz  (Read 726 times)
Offline porousTopic starter
« on: November 23, 2021, 11:04:25 am »
Hello all,
I recently bought the Aritsu VNA-DL 1-8800 MHz for around 400 USD plus tax/customs from Russia and would like to share some results:
- measures S11 and S21
- plastic housing, doesnt get too warm, calibration seems to be quite stable over time
- measured output power varies from - 20 dBm to -10 dBm. At 8800 MHz it is down to -30 dBm.
- I calibrated using SOL+T method, result is nice but if I measure short behind a short coax cable I see ripples that were not able to remove by adding an electrical delay
- measured short behind a long cable (1m) and the ripples grow...
- measured a 3 dB attenuator in S21 without adding a cable, see some ripples
- Software has the basic functions but doesnt allow to zoom in more than 5 dB.
My guess is that for 400 USD they use a wheatstone bridge as coupler which limits the calibration performance.
But 400$ for a 8.8GHz VNA....
Online jjoonathan
Re: Aritsu VNA-DL 1-8800 MHz
« Reply #1 on: November 23, 2021, 01:52:20 pm »
Cool!
I've seen these marketed as "ARINST," which seemed strange, but now that I see "Aristu" and Anritsu green in the graphs, it all makes sense, lol.
Is it using harmonics to get to 8800MHz or is that fundamental?
Thanks for sharing :)
« Reply #2 on: November 23, 2021, 02:11:49 pm »
They use harmonics. The mixers are specified up to 6 GHz only.
