Author Topic: Siglent SDS3000X HD and upgraded SDS1000X HD  (Read 423525 times)
famalex and 2 Guests are viewing this topic.
Offline Performa01
  • Country: at
Re: Siglent SDS3000X HD and upgraded SDS1000X HD
« Reply #950 on: August 02, 2024, 01:31:25 pm »
I use only the web interface. I have never used flash with SDS3000X HD.
Yes, older FW always used the same simple filename. But current FW makes that distinction and you can easily try this by repeating my experiment, i.e. saving a screenshot to a flash drive.
The Filename used for saving to flash is configurable by the way...
Offline egonotto
« Reply #951 on: August 02, 2024, 01:57:36 pm »
Hello,
the behavior when generating the file names in the web interface has changed without me having made a firmware change. I suspect that a function in the browser has been changed. I will check this by using a different browser.
My suspicion was correct. Firefox still generates names like ScreenImg(2).png.
So it was the Edge browser.
Best regards
egonotto
The following users thanked this post: Performa01
Offline 2N3055
  • Country: hr
« Reply #952 on: August 02, 2024, 02:14:37 pm »
Let me remind everybody that if you create a map to a folder on your PC (using SMB Client), then you can directly save to PC.
Also, since scope remembers last filesystem used, once you save to PC firstly, from that point on it will keep saving there.
So you press [Save]button on scope, and screenshot ends up on a PC. Or data, whatever is set.
Pay attention that 3000xHD saves data to PC at almost 100MBytes/sec... It is very fast.
The following users thanked this post: Performa01, egonotto
Offline Bad_Driver
« Reply #953 on: Today at 06:16:50 pm »
My workflow is easy. Making a screenshot in the web interface, open it in the download folder with Irfanview (my standard image viewer), invert it for printing or combine it with other snapshots and store it in a dedicated folder with an dedicated name for later use as JPG.
The following users thanked this post: Performa01, egonotto, 2N3055
Offline 2N3055
  • Country: hr
« Reply #954 on: Today at 09:21:24 pm »
And that is what I also do..
But sometimes, as you work on something, you can simply document things as you go, directly from the scope. Or when testing a small batch or repeating measurement while making changes on circuit. There are many scenarios where it is simply more ergonomic not to jump between PC and what you work on.
We are fortunate that we can choose way that suits us best.
