I programmed four EPROMs, verified them, and placed them in the corresponding sockets. Unfortunately, I got the screaming beep of utter panic at power on.
I've attached a photo of the board to show where I put the EPROMs. The unmarked PROM is the XXXX one, of course.
Lastly, I re-verified the EPROMS with the TL866-II programmer. They verified correctly, and I can definitely see 8-bit text in the hex data.
I also verified some of my original EPROMs against Marc's. I'm verifying correctly.
I see no other DIP switches, and mine are configured as yours are. I do see two jumpers near the CRT section. Both of mine are closed. I've played with one, and it disables the CRT. I'd imagine it keeps the high voltage section off during development and test.
Ideas?
