Do note that even if your scope has the sensing rings, you still need specific probes with the sensing probe and resistor. And switchable 1X/10X probes typically won't have that, with the exception of one Probe Master model. Also, the scope may not sense all probes, my Siglent SDS2354X only correctly senses 1X and 10X, which is annoying when you have 100X probes as well.
