Author Topic: dsox3000t: can i turn off sinc interpolation?  (Read 2124 times)
Online JPorticiTopic starter
« on: July 27, 2017, 11:34:52 am »
Evaluating this scope, I have a loaner next to me right now, I want to turn off sinc interpolation.. Can i do it? I can't find any option on the scope, manual doesn't mention it  :--
Offline Wuerstchenhund
  • Able to drop by occasionally only
Re: dsox3000t: can i turn off sinc interpolation?
« Reply #1 on: July 27, 2017, 12:58:42 pm »
If I remember right then these scopes automatically switch between Sin(X)/x and linear interpolation depending on the timebase setting.
Offline voltsandjolts
« Reply #2 on: July 27, 2017, 01:11:33 pm »
The Agilent 6000 series with "Display > Vectors" option off will display dots. Totally different scope of course but maybe the keyword you are looking for in menus is 'vectors'?
« Reply #3 on: July 27, 2017, 02:29:43 pm »
This is pretty much just switching interpolation on and off, but as far as I remember the decision which interpolation is used is made by the scope only.
Offline MarkL
« Reply #4 on: July 27, 2017, 03:39:56 pm »
I don't think it's possible to turn off interpolation.  If you want to see the points without interpolation, you can download the raw waveform record and look at it externally.
Offline blacksheeplogic
« Reply #5 on: July 27, 2017, 07:57:27 pm »
No. Also, the only documentation I found on this when I first got the scope was the FAQ.
http://www.keysight.com/upload/cmc_upload/All/2000_3000_X-Series_FAQ_2011-07-07.pdf
« Last Edit: July 28, 2017, 06:13:02 am by blacksheeplogic »
