Author Topic: Help identifying oscillator on keyboard logic board  (Read 661 times)
Offline newtekuserTopic starter
« on: March 22, 2022, 11:28:09 pm »
This is yet again another component from an old xt keyboard belonging to a compaq portable I.
A Google search for KSS4B shows it to be an oscillator running at 14.3MHz but pictures are different from mine (see below)
I did probe all 4 pins with my scope and it measures 4.6MHz on all so now I'm not sure if the part is not the same one or I have a bad oscillator (the keyboard throws a 301 error)
I also probed pin 6 on the keyboard connector and saw no clock signal... nothing at all.
Can anyone familiar with this part please confirm if this is indeed a 14.3MHz one?
« Last Edit: March 22, 2022, 11:30:11 pm by newtekuser »
Offline Venturi962
Re: Help identifying oscillator on keyboard logic board
« Reply #1 on: March 23, 2022, 01:02:27 am »
Here's a similar keyboard with 'KSS3M' marking so 'KSS4B' may not be helpful to understand what the part is: https://forum.vcfed.org/index.php?threads/compaq-portable-i-corroded-keyboard.57223/
This also shows that the chip next to it is a INS8035-6 (datasheet attached) which looks to max out at 6MHz, 4.6MHz would seem alright.
« Last Edit: March 23, 2022, 01:34:24 am by Venturi962 »
« Reply #2 on: March 23, 2022, 05:11:42 am »
Is there any correlation between the 4.6MHz and the 6MHz IC next to it? That does have two XTAL pins but I thought it's running off its own internal oscillator.
