As another poster stated, 2+16 on an MSO isn't a bad option, I'd rather have that or even 2+8 than 4+0 in most circumstances. The exception is when I'm doing switch mode power supplies when even 4 analogue channels can seem limiting.
But it depends to a large extent what you do, if you don't do much digital then the digital channels will be largely superfluous.
One further thing: remember that most 2 ch scopes have a trigger input too, which in some instances can be a reasonable compromise. A one channel scope without an external trigger offers little more than a 2.5 digit DVM for practical purposes.
Edit: meant to say, two channels can do anything a four channel can do, just not at the same time. You just need to work a little harder. Remember that 4ch scopes have only become commonplace on the average bench in the past fifteen years or so.
"One further thing: remember that most 2 ch scopes have a trigger input too, which in some instances can be a reasonable compromise. A one channel scope without an external trigger offers little more than a 2.5 digit DVM for practical purposes."
I've never encountered a single channel Osciiloscope without an external trigger,even the cruddiest 10MHz analogs have them.--------not sure about the little "toy" pocket DSOs,though!
That was almost what I was referring to. I have a Velleman HPS10 LCD scope from many years ago, single channel 10MHz, no trigger, almost useless. I think I ever used it other than to switch it on to see if it worked, I couldn't find a reason to use it. There are others, the UT-81B for example.
On your other point,I've fixed equipment faults using a single channel BWD 'scope with a faulty trigger circuit,which were impossible to get a handle on using a DVM/DMM.
A DMM will be sufficient for many jobs,but some really do need a 'scope.
In those cases,any 'scope,is better than none.
I did say "A one channel scope without an external trigger offers little more than a 2.5 digit DVM for practical purposes", so I didn't completely discount it, but I still think it'd most likely end up in a drawer gathering dust unlike a DVM or certainly a DMM. :-)
I think we agree in general, I was just trying to dissuade anyone from even considering a single channel scope without an external trigger on it.
Out of interest,I Googled for Velleman HPS10,& found the linked pix.
http://www.vellemanusa.com/images/products/0/hps10_f3.jpgOhh! The horror!
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
I then had a look at a few Youtube reviews,& things didn't get much better!
I also saw one for the UT-81B,
At least,Uni-T had a pretty good shot at the DMM part,but the 'scope bit was still quite dismal.
On the other hand,although
this thing
* looks like it was designed to be operated by "Cabbage Patch Dolls",it is a real,usable test instrument,after you get past BNC connectors that become unscrewed,& knobs that fall off.
*http://www.eham.net/data/classifieds/images/364574.jpgThe "10MHz" in the spec is the 3dB down point,but it will still display up to 27MHz or so--obviously without voltage accuracy------
and it has an external trigger!
