Hi Nx-1997, :-)
Tonight I managed to pair my 34401A with your HP34401A software.
Some comments, but first my thanks for sharing this software!
I had started last week with an RS232 USB dongle, but with three different computers, this dongle did not want to work properly.
I have a special measurement computer that has only 1 RS232 port and the sad thing is that I still have a plug-in card with two RS232 ports on it but there is no PCI slot left in this computer...
So I ordered two RS232 to USB cables with another chipset in it and now I hope that those will work. :-)
1e
In the graphics module, the bottoms of the letters of the menu are cut off.
![](https://www.bramcam.nl/Diversen/34401A-software-01.png)
2e
The main menu shows the measured value, e.g. the voltage of my 10V DC LAB reference.
Below the measured value are then the minimum value and the maximum value and finally the average value.
I would like to be able to reset the minimum and average value with a button, is that possible, I have not been able to find this function yet.
![](https://www.bramcam.nl/Diversen/34401A-software-02.png)
3e
I am also missing another feature and that is the "Null" button.
4e
On my 34461A and 34465A multimeters I often use this Null button and set the scale to e.g. 1PPM/Div
Is it possible that you could apply something similar to this software as well?
Here the 34401A is used to measure my LAB reference.
The 34401A has been on for less than 1 hour so there is the warm up drift to be seen here.
The value of the vertical scale jumps back and forth, the last "0" is omitted and this gives a jittery picture.
![](https://www.bramcam.nl/Diversen/34401A-software-03.png)
For now, these are my comments, I think the software is a nice piece of work!
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Thanks and kind regards,
Bram
