@BravoV The Autosol looks like it may be similar and probably work even though it is targeted at Aluminum.
Thanks, and other question on using the rotary fabric buff with this kind of paste when used at the bnc connector surface.
I know you've mentioned the words "slow speed", its just sometimes I'm so worry at this process, it may eat off the outer chrome (or is it nickel ?) plating too much, and will starting to expose the inner yellowish brass base metal, that will be my nightmare.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
Just stop when it is enough bling/shine ? or I'm just worrying this way too much ?
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Also once finished buffing, did you apply any extra coating at these metal surface to protect it ?
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91383;image)
Hope I'm not bugging you too much.
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
