The meter face was a major concern as it was very yellowed and peeling.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91415;image)
Looks like the emusion was affected by whatever the corrosive atmosphere was.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91417;image)
This is after I cleaned off what looked like a fine powdery fur over all the metal parts. I used one of those adjustable fiberglass brushes which worked very well at removing it without disturbing the metal. Extremely sensitive parts here, it would be tempting to blow this out with an air duster but that could easily bend/break the movement. I used a soft artist brush to sweep all the debris out.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91419;image)
At first I wondered how I was going to replicate the meter face with my camera and keep the scale. And I was thinking I would have to use some photo shop to remove the flaking and fading. Then I read a thread on here about taking pictures of circuit boards with a scanner. That took care of the scaling issue, now I just need to learn how to touch up the image. Then the light bulb went on, set the scanner to one bit mode. That gave a perfect black/white only image that was perfect with no processing needed. Notice the brownish fading on the original on the right.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91421;image)
The new face assembled in the meter.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91423;image)
The new meter face printed out on Papillo self adhesive photo film (upper left). Meter face plate with the original graphic removed (lower right). Notice chromed surface for when it would be used for a mirrored face. It was very polished but I scuffed it with a sanding sponge for better adhesion. I had to figure out how to get the photo film applied precisely on the meter face plate. The cardboard is about 2mm thick which is slightly thicker than the meter face plate. The two cardboard pieces were cutout together with a window slightly larger than the meter face plate.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91425;image)
Double stick tape applied to the perimeter of the opening of one cardboard piece.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91427;image)
The protective strip of the double stick is removed and then the cardboard is stuck to the printed side of the sticky photo film. Notice the alignment windows that I cut at the corners so I will be able to see the metal meter face plate through the overlay.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91429;image)
The above flipped over and the protective layer of the sticky photo film is removed and the other cardboard piece is stuck down on the sticky side of the film.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91431;image)
The metal meter face plate is placed on the table and then the whole cardboard framed photo film unit is carefully aligned over it. The cardboard being slightly thicker than the metal face plate allows precise positioning without sticking until you want it to. When in position I used a piece of the protective backing to press down the film to contact the faceplate. It is very important to press down in a wave from one edge to another to not trap any air bubbles.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91433;image)
Flipped over showing the faceplate stuck in proper position
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91435;image)
An Exacto knife trip around the perimeter to free the meter face.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91437;image)
Two rubber washers and Nylon screws keep the face plate electrically isolated from the meter mechanics. Notice the stud that gets connected to a ground wire to drain charge of the faceplate that could influence the needle.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91439;image)
Aged bakelite and dirt.
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91441;image)
After a polish with PlastX
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91443;image)
Using the 2450 SMU to test the meter at full scale. It is a 100µA meter so not bad being only 4µA off at full scale. The smallest increment that I could see needle response was about 100pA
![](https://www.eevblog.com/forum/testgear/hp-3410a-ac-microvoltmeter-restoration/?action=dlattach;attach=91445;image)
More to follow…
