Author Topic: difference between rebadged scopes and "original" counterparts?  (Read 4967 times)
Offline JPorticiTopic starter
It is known that "budget" test equipment from premium brands is usually a rebadged product, designed and manufactured by a "less premium" brand.
The usual examples
Keysight 1000 series scopes vs rigol ds1000 series
Lecroy wavesurfer 3000 vs siglent sds 3000
but is there any difference between the two besides a different paint job and -of course- price tag?
a better firmware? better accessories?
Re: difference between rebadged scopes and "original" counterparts?
« Reply #1 on: July 06, 2016, 08:37:19 pm »
Several.
In some cases the FW is different and in others only the GUI and external labeling is changed with re-brands.
Often the "top of the range" in a series is only OEM and the re-badges have less memory.
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #2 on: July 07, 2016, 05:23:46 am »
The usual examples
Be careful, the WaveSurfer 3000 is *NOT* a rebadge, it's hardware has been designed by Siglent with the help and under the control of LeCroy, and the software on that scope is solely developed by LeCroy (Siglent can't touch it, which considering their track record in firmware was a very wise decision). Siglent can sell the scope under their own brand in China (where it is sold as SDS3000) only, LeCroy has pretty much the rest of the world.
Such agreements aren't new for LeCroy, which has already done them in the past (i.e. with Iwatsu, which made the LeCroy WaveRunner LT, WaveRunner 2LT and WavePro 900 scopes hardware and which were sold as Iwatsu in Japan).
Also, while the WaveSurfer 3000 is notably cheaper than say the Keysight DSOX3000T, with a starting price of $3000 it is hardly in the "budget" range.
The rebadges in LeCroy's portfolio are the low-end Series WaveAce (all Siglent SDS1000xxx Series scopes), WaveJet (rebadged Iwatsu DS-5000 Series scopes) and the WaveStation Series of AWGs (again all Siglent SDG1000/SDG5000 rebadges). Because they are rebadges, there's no agreement for the OEM to limit sales of the original product to a certain area.
With rebadges, as the term implies it's the ODM hardware just carrying the big brand label. Differences are generally limited to mere optics, i.e. different paint jobs on the housing, and a different color scheme in the UI. Deviations from the original product are usually very limited to keep costs down, and cost is pretty much the main reason a big brand goes for rebagded products.
« Last Edit: July 08, 2016, 11:36:40 am by Wuerstchenhund »
Offline billfernandez
« Reply #3 on: July 07, 2016, 06:15:09 am »
The difference can be whatever the two companies negotiate them to be.  In some cases it will be just the second company's nameplate on the first company's "white label" product.  In other cases it will be upgraded components, or more careful testing, or adding a feature or two, or an unique configuration.  In other cases one company (e.g. Apple) will design a product and have a second company (e.g. Foxconn) manufacture it.  Etc.
Offline Fungus
« Reply #4 on: July 07, 2016, 06:36:16 am »
Since Keysight has a low cost manufacturing facility in Malaysia, why not they just create their own stripped down and crippled version to compete Chinese brands? Why rebadge a Rigol?
R&D costs.
What makes more money? Spend a year or two in development or start selling tomorrow.
The following users thanked this post: Kilrah
« Reply #5 on: July 07, 2016, 07:13:57 am »
The same for LeCroy, they can simple rent or build a factory in China or Malaysia and start manufacturing their scopes at much lower labor cost, then leave the final adjustment and calibration to their US base.
I see some US businesses manufacturing their PCBA in China, then do the final assembly in the US, so technically it is still made in USA, but with much less labor cost. Why LeCroy can not learn this? For their production volume, offshore should be cheap than made in USA, unless they have much lower market share than I thought.
Because entry level and/or low BW units are not their core business.
They (and other brands) just want you as part of their family for the chance of future sales of their high end products.
Offline coppice
« Reply #6 on: July 07, 2016, 07:23:47 am »
How big do you think their production volumes are? The DS1054Z is a hit product, and even those have only reached a few tens of thousands, according to ads you can see proclaiming this as really big volume. Most instruments above the most basic DMMs are made in relatively small numbers, by the standards of most electronics production. People like Siglent are probably only achieving big enough volumes to make their production economic by making scopes for other people. Dividing production up further just increases everyone's costs.
Offline Tepe
« Reply #7 on: July 07, 2016, 08:35:34 am »
"[The] hardware has been designed by Siglent with the help and under the control of LeCroy" sounds like marketing copy. As for the software, maybe it was done solely by LeCroy, but then again, it's not cheap to write software so why do it from scratch; get Siglent's source code and customise it is a more realistic proposition and much more plausible.
« Reply #8 on: July 07, 2016, 09:10:12 am »
Conjecture on the merits or otherwise of LeCroys involvement in the development of the 3000 series is a little pointless for a product that's been on the market for ~2 years.
Here's the thread:
https://www.eevblog.com/forum/testgear/siglent's-new-products-sds3000-series-oscilloscopes/
« Reply #9 on: July 07, 2016, 09:38:13 am »
Big brands don't do it because it's not cost effective. Setting up your own production facilities and designing products for the lowest possible price requires investing a lot of money and ressources up-front, when they can just buy cheap products made to order from existing outfits?
This is even more true for LeCroy, which pretty much is a brand bought for its capable mid-range and high-end scopes. It's is offering a wide range of mid-range and high-end scopes which are developed in-house, and that has and still is LeCroy's core business where they make the big bucks from. They know very well that engaging in the low-end is a race to the bottom, especially today with all the cheap Chinese kit. Why should they waste valuable ressources that are better spent on high value stuff when buying rebades does the job?
« Reply #10 on: July 07, 2016, 09:46:02 am »
It might sound this way to you but it's simply a fact. Just try to buy a SDS3000 outside China, you'll have a hard time to even get a grey import, let alone one from an official Siglent reseller.
And as I said, these co-operations aren't a new concept for LeCroy, that's pretty much what they've done most throughout their existence (first on components, later whole scopes).
No, not really. Aside from the not so small problem that Siglent's software is crap, Siglent also has zero experience in writing firmware for a complex mid-range scope. In addition, the WS3000 is a Windows-based X-Stream scope, i.e. the software is full of LeCroy IP.
You can't get that by rewriting shitty small-scale embedded software for bottom-of-the-barrel scopes (if you want to see how that would turn out, just look at the Rigol DS6000, which offers entry-level performance and functionality at a upper mid-range price  :-- ). Plus the mid-range market isn't as forgiving as the entry-level/hobbyist market (where buyers are generally more tolerant of bugs and support issues), in this price class customers expect a reliable and mature product with a good set of advanced functionality.
And thanks to keeping Siglent away from the WS3000/SDS3000 software (Siglent only gets the protected firmware blob to flash into its SDS3000) it was a very mature product when it came out in 2014. That means the SDS3000 is probably the only Siglent scope that ever came to market without major firmware flaws. And probably will be for a while.  ;)
« Last Edit: July 08, 2016, 11:35:41 am by Wuerstchenhund »
Offline H.O
« Reply #11 on: July 07, 2016, 12:12:45 pm »
Here we go again....
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #12 on: July 08, 2016, 11:09:13 am »
The usual examples
The two examples you mentioned are not necessarily true rebranding - i.e., both Keysight and Lecroy gave inputs (or were involved otherwise) in the product development and may have given some sauce to the firmware of their own models. In the Keysight case, differences go even further given they are physically different.
I think that a better example is Lecroy's Waveace low-end oscilloscope product line, where some models are also branded as Gratten/Atten and the ODM is Siglent. Reports mention there are no differences in firmware and, consequently, bugs (reference here.
Offline Tepe
« Reply #13 on: July 08, 2016, 01:27:51 pm »
Don't worry - I have read the thread tautech linked to
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #14 on: July 09, 2016, 01:53:04 pm »
OEM are contracted to do X, and the final product with the 'brand' name will be X+n, regardless of the product, DSO, DMMs, hand tools etc.,.  The amount of n really varies from product to product.  DSO aside, the thread on Dave's eeblog meter, a rebranded Brymen is a test case of what rebranding entails with much info public on the forums. Even with n ~ 0, Dave has to at least provide customer support and quality control once the units are shipped from OEM to him.  There are other examples on eevblog threads, one with a stark difference in quality are the UniT DMMs sold as Amprobe DMMs.
Best Wishes,
 Saturation
Offline Sbampato12
« Reply #15 on: July 12, 2016, 07:50:37 pm »
There is the aftersales differences too. The 'different' support, lifetime, support, assistance...
Those are regularly better (or we expect to) with the most famous brands.
But sometimes, even that doesn't make big diffences (hobby, for example)
