Author Topic: In this picture can you ID the component that senses temperature?  (Read 3395 times)
Offline alank2Topic starter
« on: September 08, 2013, 10:47:00 pm »
A rubidium module fits in the square cut out and part of this units management provides a rubidium temperature, but the rb module does not have an onboard temp, so I think it must be on this board.  Probably in the upper left someplace - the picture zooms in quite a bit - can you identify which component senses the temp?
http://www.ko4bb.com/Manuals/05%29_GPS_Timing/RFTG-m/RFTG-m-rb_L105A_Hi_res/lucent%283%29.jpg
Thanks,
Alan
Offline firehopper
Re: In this picture can you ID the component that senses temperature?
« Reply #1 on: September 09, 2013, 03:36:36 am »
Thanks,
Alan
it could be almost any diode or resistor, but it may possibly in one of those metal cans as well
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: September 09, 2013, 06:33:17 am »
It could be on board the microcontroller as well... Some cpus have built in temp sensors
Offline ablacon64
  • Country: br
« Reply #3 on: September 09, 2013, 11:42:21 am »
As other pointed I don't know where the sensor is but something caught my attention: What is FL102 and FL103? Looks like a ceramic capacitor in a coil's enclosure....
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #4 on: September 09, 2013, 12:40:17 pm »
It is an EMI suppression block by Murata: http://search.murata.co.jp/Ceramy/image/img/PDF/ENG/L0117BNX00.pdf
Apparently kind of like a ceramic cap with big ferrite beads in its "legs".
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline Orange
« Reply #5 on: September 09, 2013, 03:11:47 pm »
Why do you expect a temp control on this board ?
The rubidium module used in here is an Efratom LPRO-101. This is an autonomous module. It only needs a good thermal contact between the box chassis and the bottom side of the module.
« Reply #6 on: September 09, 2013, 03:45:50 pm »
Because I don't see any place in the LPRO interface where it can indicate its temperature.  It is bolted to the floor of the RFTG which is basically a giant heat sink.  The board above sits around it.  The temperature the management software indicates is higher than my sensor and suggests the area of the LPRO where the Rb physics package is near.  I wonder if the temperature is pulled into the board via the single pcb mount in the upper left and something on board is used to sense it.
I've attached a sensor to the other side of the LPRO (where the interface port is) because I made a small aluminum adapter that lets me press a TO92 sensor up to the LPRO case.  The management software shows 48.5141 C, but I've got a PID control loop running an AVR that varies a fan RPM in an attempt to keep the LPRO stable temp wise.  So far it is working well and has been keeping the temp at 40 deg C +/- 0.15 C.
I'm just curious is someone could recognize the where on the pcb the temp might be being sensed.
Thanks,
Alan
Offline ablacon64
  • Country: br
« Reply #7 on: September 09, 2013, 11:02:20 pm »
Thanks! :)
