This is to all of you who are afraid to spend too much money on a scope that they don't know if it works or not. I'll try to show (hopefully) how to restore a scope in the most awful condition you can imagine.
OK so recently I got a HP 1741A 100MHz dual channel analog storage scope from ebay for an insanely low price. This picture was in the auction. Although a bit dirty, it looked quite promissing.
![](http://www.leonborg.de/auktion/hp1741aossigliA.jpg)
The package arrives. The scope was very well packed indeed. The box was almost a meter high.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC05570.jpg)
This is how the scope looked when taken out of the box. As for the picture in the auction, appearances can be deceiving.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC05575.jpg)
Shot of the scope from above. Notice I immediately unplugged the anode lead and touched it to ground just incase.
As for the carpet......dot't ask.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC05572.jpg)
So first thing to check in an analog scope is the CRT. Prying off the rusty base connector wasn't easy.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC05573.jpg)
Tube lifted to slide out from the CRT shield.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC05578.jpg)
CRT on the table. It doesn't look good. The getter evaporated.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC05579.jpg)
The neck of the CRT is broken so this one is useless.
![Cry :'(](https://www.eevblog.com/forum/Smileys/default/cry.gif)
(unless you've got an induction heater, diffusion pump, glass blowing lathe.... you get the picture).
Sadly I don't so what now? The electron gun makes a nice ornament though.
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC05580.jpg)
It's a too nice scope to throw away or just use for parts so after a bit of searching I found a used CRT on ebay and the restoration will continue.
I will post more information as the restoration continues. Comments appreciated.
