Hey all,
I have an HP 4192A impedance analyzer with four very tired BNC connectors on the front panel. The center pin sockets are splayed out and make intermittent contact with any cables or test sets that I connect to them. (I attached a photo of the very sad looking center pin socket.)
I'd like to replace the entire connector or at least the center pin socket/receptacle, but I'm having trouble finding information about how the connector is constructed or where i can find a suitable replacement.
The service manual lists the connector as HP part 1250-0252, which was used in lots of equipment from the era. This part is available from Keysight, albeit at a high price. However, it's not obvious from the service manual or part drawing if the replacement connector comes with a new center pin. Does anyone know if this is the case? Is the center pin considered part of the connector assembly or is it a separate part, and if so what is the part number for the center pin by itself? My concern is that the center pin might be considered part of the cable assembly that attaches to the connector, which is obsolete/NLA.
Is there a guide to repairing these connectors online? I am having trouble finding much information, which is surprising given how common these connectors are in older HP equipment.
Lastly, is there a cross reference for the connector and center pin to a less expensive and more readily available connector from Amphenol, TE, etc?
